Page 1 of 3 123 LastLast
Thread: Disco II tire question
  1. #1
    Default Disco II tire question
    So I am a new owner of a spiffy 04 disco II and am looking at adding some 33' tires to it. I live in Colorado and am looking for more axel clearance for the perpetually rocky trails. How much lift is necessary to do this?
    The RTE kit looks great but $$$.
    ARB looks great, but light on lift.
    Thanks for the feedback. I also don't want my truck to look like a goofy jacked up pick-up, do I need to back off on tire size?
  2. #2
    Join Date
    Sep 2011
    Location
    Falcon, CO
    Posts
    631
    I've got the OME 3in suspension and a 1.25in body lift the tires will still rub a little at full flex. if I were doing it again I'd spend the money on a 4in kit. Here are 2 shots of mine sorry they don't show everything better they are the only ones I still have on my iPhone
    These were taken on a trail off Gold Camp Road near COS
  3. #3
    Al, thanks for the reply. What's the story with drive shafts? At what point do the need to be replaced with longer to account for the lift?
  4. #4
    Join Date
    Sep 2011
    Location
    Falcon, CO
    Posts
    631
    After you go past 3in you need to replace the drive shafts. I wouldn't let that scare me away from it though. Tom Woods are reasonably priced and alot stronger than the factory setup, you can get rid of the flex plate. It may just be the rear that needs changed too, not both.
  5. #5
    Join Date
    Sep 2011
    Location
    Falcon, CO
    Posts
    631
    What part of CO are you in?
  6. #6
    Join Date
    Aug 2009
    Location
    In the oven...aka Tucson
    Posts
    356
    I ran 33's on my D2 with a 3" lift, only rubbed on the front radius arms. Did you extend your bumpstops? It's always seems to be forgotten about when lifting a truck...Not a fan of body lifts, especially on the D2 because you can fit up to a 35 without having to cut or trim.
    01 D2 FZJ80 axles ARB/Detroit 37" Iroks, (F)14" 9100 Coilovers 14" (R)14" FOA Coilovers 1.6 lt230 PSC hydro steering
    96 D1
    1983 110 RHD Pick up
    KF7EMF
  7. #7
    Join Date
    Sep 2011
    Location
    Falcon, CO
    Posts
    631
    I wouldn't say I forgot to add them. I choose not to extend the bumpstops because at full stuff the spring limits it before the shock would be damaged. Now if they rub it is only on the radius arms, at full lock. If the shock was limiting it I would have extended them. I'd rather have more flex both ways than just down. If someone put 35's on with a 3in lift, without trimming or rubbing then I'd bet they don't have much up travel due to the extensions. When I put it together I tested it out on some nice pitchy areas to make sure it was all setup right. The body lift ain't bad on the D2 just a slight gap at the front bumper. The rear was easy to relocate. It was a PIA getting all the carpet out. I doubt I'd change mine now everything is working great as it is.
  8. #8
    Join Date
    Jun 2010
    Location
    Columbus, Georgia
    Posts
    593
    I fit 33's with 2" RTE springs but have since added 1" spacers. I got some occasional rubbing without the spacers and almost none with them. It's a bump up from the standard 2" but less than the RTE 3" which actually sits over 4". This spring set up with the TerraFirma 2+ shocks would be a very economical and capable set up
  9. #9
    Join Date
    Apr 2008
    Location
    Marshville, NC, USA
    Posts
    1,764
    I like a 3" front, 2" rear lift on a D-II which allows 255/85-16 like it was made for it. Check the sold page on my website for several trucks so fitted.
    '13 F-150
    '86 110 3-door
    '97NAS90--->130
    TreadLightly! Trainer
    www.thervrbarn.com
  10. #10
    Join Date
    Oct 2010
    Location
    Cochise County, AZ
    Posts
    622
    Quote Originally Posted by cdavis3361 View Post
    In my opinion, Discos are svelte expedition vehicles that quickly lose their class when built like "HardKore Krawlers."
    2006 LR3
    2006 KTM Adventure 950
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
