Page 1 of 4 123 ... LastLast
Thread: GM fan clutch
  1. #1
    Join Date
    Jan 2010
    Location
    Georgia's Golden Isles
    Posts
    248
    Default GM fan clutch
    Apologies to the purist in our company.
    My stock fan clutch was dead and I was beginning to get the worrisome heat spikes in traffic and off road. After researching the alternatives I decided to try the GM unit (....research seldom leads to GM, I know....) I made the decision based on: availability, effectiveness and finally- cost.
    I installed the $42 super duty (I think that's what it's called) GM fan clutch in my 96 D1 about a week ago and I'm happy to say it works like a charm. The noise is considerable at low speeds but that's because of the huge volume of air that is being moved. As the truck reaches hwy speeds the noise is hardly noticeable.
    My heating problems are gone- which certainly would have happened with a OEM part as well- and I'm happy with the way it has worked out.
    Best,
    DB
    __________________
    1996 Land Rover D1 SD *expo white*
    2000 Suzuki DRZ 400, Acerbies 4.2 tank *in black*
    2007 Suzuki DL650 (Wee Strom) (understated grey)
  2. #2
    Join Date
    Oct 2009
    Posts
    217
    pics... model number, etc....
  3. #3
    Join Date
    Dec 2011
    Location
    Ontario, Canada
    Posts
    172
    That is good to hear. I have been thinking that with a hot summer already here my stock and either stuck or semi-freewheeling fan clutch is definately due for replacement. I read about the gm unit on a different land river forum. I may have to give it a shot.
  4. #4
    Join Date
    Jul 2008
    Location
    Georgia, USA
    Posts
    2,994
    According to L/R the D1 (89-98), Defender (87-06) and RRC (92-94) are the same so these should fit them all (I've only tried them on my D1 V8)
    Fan Clutch
    (36mm hex)
    Std Duty
    Imperial
    215157
    Severe duty
    Imperial
    215158
    Hvy duty
    Hayden
    2991
    Metal Fan Blade
    Imperial
    220618
    Imperial clutch uses larger fan blade bolts (10mm I think)
    Hayden uses the OE bolts
    Imperial fan blade requires the blades to be trimmed about 1/8"
    Edit: corrected Std duty PN to 215157
    Tom Rowe
    Four wheel drive allows you to get stuck
    in places even more inaccessible.
    62 88 reg
    67 NADA x2
    74 Air Portable - The Antichrist (tag 6A666)
    95 D1 5-speed
    95 D90 5-speed
    97 D1 Automatic
  5. #5
    Join Date
    Aug 2008
    Location
    Cookeville, TN
    Posts
    139
    Your over all mpg will drop some. Save the OEM clutch for winter time.
    BTW If anyone is interested in this set up, I have a Imperial HD clutch for sale with the OEM fan and correct bolts. Ready to install. $45 shipped
    Chris Robinson
    97' Land Rover NAS DI
    08' Conqueror Base Camp
    02' F250, Crewcab, 4x4, 7.3 Powerstroke
    10' Lance 825
  6. #6
    Join Date
    Jan 2008
    Location
    State College PA
    Posts
    190
    I paid about 34 bucks for the Imperial 215257 fan clutch from advanced auto parts. I used an online code "retmenot123" and picked it up at the store. Bolts are M10X1.5X15mm, you can find these in the help section listed as GM torque converter bolts. Oh, and the fan clutch was made in the USA!
    Sven
    97 D1
  7. #7
    Join Date
    Feb 2011
    Location
    CA-Central Coast
    Posts
    63
    Quote Originally Posted by High Center View Post
    I'm guessing by the price that this is an aftermarket clutch. If you buy an AC Delco brand clutch, it will likely function better an not be on at low speeds when the engine is not hot.
  8. #8
    Join Date
    Apr 2012
    Location
    PA US
    Posts
    121
    Quote Originally Posted by SteveG View Post
    Or just not buy some $40 cheap Chinese made knock off at AutoZone. I spent $100 on something that was obviously of high quality at a "real" parts store (you know, the kind actual garages buy parts from) and have had no issues nor lost any "mileage" (a joke to even discuss in the same sentence as these trucks) over the last year.
    Yes, you do get what you pay for when you buy cheap. And if you spend some real money you might get what you pay for. If you spend some real money and actually know what you are buying you WILL get what you pay for.
  9. #9
    Join Date
    Feb 2011
    Location
    CA-Central Coast
    Posts
    63
    Quote Originally Posted by Daryl View Post
    I work at an auto repair shop and refuse to install any aftermarket fan clutches unless there is a major budget issue. Even the "good" clutches from "real" parts stores are junk. They turn on too often and just don't work as well.
  10. #10
    Join Date
    Jul 2008
    Location
    Georgia, USA
    Posts
    2,994
    Hayden/Imperial are a division of SMP and the fan clutches (and oil coolers) are made in Grapevine, TX. In addition to replacement clutches, they are OES for car companies.
    Tom Rowe
    62 88 reg
    67 NADA x2
    95 D1 5-speed
    95 D90 5-speed
    97 D1 Automatic
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
