Jakes01234
Well this is just a feeler as i need something more family friendly and im on the fence selling it and getting something else or just keeping it and leaving it at my vacation house..
Its a 2000 4.0 auto with just over 50k on it.. I have OME extremely stiff springs the zj v8 front and the lj rear, All the control arms are Currie and shocks are also OME..
I built the bumper when i first got it, they arent the best but they are solid.
I have a ford 8.8 in the back with the super 88 chromo shafts and an ARB. The front is the factory LP D30 with chromo shafts and higher spline counts with an ARB aswell.. But i have a D30 HP that would go with it so you can swap over all the parts except the gears you would need the reverse cut.
I have a vair 2.5 gallon tank and compressor with 2 quick disconnects at the doors.
Have a big tie rod i bought a long time ago and im sure a currie currectlync would make it waaaay better..
There is no carpet it was torn out and bedlined but it was done quickly so its no professional job.
There is a cb and aftermarket radio and speakers.
It has 5 matching pro comp mud terrains on crager soft 8s two are really good i think two are past half way point.
I never really went hard wheeling i usually used it to just get to a camping spot or a joy ride through my property, the body is scratched and a few little dents. Have 5 rubicon wheels that are in good shape but a few rock rubs that would go with it. Frame is in good shape aswell. Have a hard top and a best top sailcloth top with tinted windows. Has no AC or cruise control..
Also has a brown dog MML. Some recent service done at 48k was tranny service, coolant flush, rear main seal was dribbling, and transfer case flush, also stock exhaust had a few holes so it was replaced with one from kolak..
Before it sells i will replace the steering box because that just started leaking last week and the radiator because it also leaks a little..
I did a custom highline front and rear to fit to go after that LCOG idea..
I use it as a DD now to commute back and forth to work and i just have no time to finish throwing parts at it, House kids dog business are taking up alot of time..
Would like to see it be used seeing i have put alot of money into it with some good parts and it just sees pavement.
Im thinking 14k but if thats way out of whack let me know feel free to shoot some offers see if im comfortable letting it go..
Title in hand and its clean..
Some of those pics are before the highline i believe
