Thread: Safari Snorkel Mass Air flow Sensor
  1. #1
    Join Date
    Oct 2011
    Location
    Albuquerque
    Posts
    61
    Question Safari Snorkel Mass Air flow Sensor
    What do you with the Mass Air Flow Sensor after installing Safari Snorkel?
    Thanx
    Forgot vehicle specs: 1994 Mits Montero 3.5 liter
    Keep smiling
  2. #2
    Join Date
    Jul 2008
    Posts
    700
    Nothing! just keep it clean, you can buy air sensor cleaner..
  3. #3
    Join Date
    Mar 2009
    Location
    Livermore, Ca
    Posts
    227
    The snorkel is connected to the air filter box that houses the mass flow sensor. Check out the folks that fabs the snorkels, they have a how to write up.
    Michael j
    TreadLightly! Trainer
    GrassCat III, 1994 Montero 5 speed stock ( for a little while ).
    GrassCat II, 1998 Montero with winter package. All the bells a whistles. Ran off with Hector.
    GrassCat I, 1991 Ran off with Justice R.
  4. #4
    Join Date
    Oct 2011
    Location
    Albuquerque
    Posts
    61
    Default thanks
    Thanks GrassCat........makes sense. Does anyone have a picture with inside installation of a Safari Snorkel? Pls
    Keep smiling
  5. #5
    Join Date
    Mar 2009
    Location
    NorCal
    Posts
    3,288
    No pics but in the engine bay you shouldn't notice much different. Most of the changes are in between the inner and outer fenders above the plastic splash shield in your wheel well. Sorry, no access to pics of that right now although I did take some pics. I'll try and remember to post them later although frankly it won't do much good since it's all common sense stuff here. IIRC I used 3 or 4" ID flexible dryer hose from the snorkel at the outer fender to the inner fender where I mated the hose to the oval intake hole of the filter housing using a flexible PVC round to rectangle adapter originally made for house rain gutters.
    To seal up the various openings I used a putty substance sort of like plumber's putty and a black tar-like adhesive backed tin tape used by contractors (it was Grasscat's so I'm not 100% sure what it was).
    Unfortunately none of the available snorkels provide the internal plumbing bits because as they've claimed to me when I've asked, the internals for each engine are all different.
    1989 SWB Montero (3.0L v6, rear LSD), 33" mudders
    1996 Montero SR (3.5L v6, rear Locker), 35" mudders, 3.15:1 xcase crawler gears
    Build Thread: http://www.expeditionportal.com/foru...su-build-up...
  6. #6
    Join Date
    Oct 2011
    Location
    Albuquerque
    Posts
    61
    Wanted to take a moment to thank everyone. I spoke with the retailer and the MFG and I feel confident everything will fall into place. Good wheeling
    Keep smiling
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
