View Poll Results: Everything else equal, I would prefer solid axles to independent suspension
Voters
97. You may not vote on this poll
  • True, I prefer solid axles
    64 65.98%
  • False, I prefer independent suspension
    24 24.74%
  • False, I have no preference
    9 9.28%
Page 3 of 3 FirstFirst 123
Thread: T of F: Everything else equal, I would prefer solid axles to independent suspension?
  1. #21
    Join Date
    Oct 2010
    Location
    AZ
    Posts
    120
    IFS for me personally. I can always upgrade to a long travel set up in the front. I was back and forth between a WJ Grand Cherokee (SFA) 80 series, and my current 4Runner....The 4runner was the only one with IFS, which is why its in my garage.
    i have still taken it on plenty of rough jeep trails, just a little trickier and easier to lift a wheel into the air. but my wife enjoys the ride much more. and hitting dirt roads at speed is more enjoyable.
    Everyone has their preferences though. and I agree TTB is a sweet set up!
    '97 limited
  2. #22
    Join Date
    Jun 2011
    Location
    Ohio
    Posts
    523
    Quote Originally Posted by enigmadsm View Post
    Do you mean that goofy split dana50 thing on OBS F150's and fullsize Broncos??? With all the alignment problems and +camber change like a Econoline van? I'm going to pretend I didn't hear/see that.
    '08 Ford F250 XL
    Half of a '94 Jeep YJ
    '02 Honda CRF450r, '04 Ford Mach1
  3. #23
    Join Date
    Dec 2011
    Location
    So. California
    Posts
    365
    Quote Originally Posted by Buliwyf View Post
    Keep on pretending then... lol It IS infact a great setup, though only if you build it properly (something much of the lift industry hasn't made real easy to do unfortunately, and is why you often see the steering & alignment issues you do with them).
    Also, it's a Dana44 on the F-150 & Bronco. The F-250 got the D50 (and I will concede the F-250 leaf-sprung version is quite lame, but the coil-spring/radius arm TTBs are very durable & buildable for lots of flex/travel even on a small budget, something that can't be said of pretty much any other factory IFS offering. Virtually any locker can be fitted to one as well).
    1990 Ford Bronco II, dual t-case, locked up on 35s
  4. #24
    Join Date
    Nov 2006
    Location
    Tucson, AZ
    Posts
    4,141
    OP: Couldn't vote because it depends on the vehicle and the application, as in reality not everything is equal.
    Whether it be SFA, IFS, or TTB, I prefer coil springs over other types of springs such as leafs or torsion bars.
    Quote Originally Posted by 4x4junkie View Post
    Auto Fab, Giant Motorsports, Camburg build decent TTB's...
    http://www.autofab.com/
    http://www.giantmotorsports.com/
    http://www.camburg.com/store/susp-sy...unner-4-0-kit/
    If you haven't seen this thread on GoFast Broncos.
    http://www.gofastbroncos.com/forum/v...php?f=19&t=864
    ...and Speed Unlimited goes over the top with their full custom fabbed TTB
    And Hell, who needs 4WD?
  5. #25
    Join Date
    Jan 2006
    Location
    Reno, NV
    Posts
    1,001
    Ford TTB description.
    Also I didn't write it, so don't blame the spelling on me.
    The History of TTB
    "TTB tech and enlightenment article
    Fords TTB *twin traction beam* first showed up on the 1980 model
    Ford 1/2 ton truck line. Ford credits a fella at Ford engeneering
    named "Rupert B Tard" for the concept and design of the TTB.
    Although it is widely understood that this design was a copywrite
    swindle if there ever was one, but Bolens, makers of fine
    garden/lawn tractors was not interested in pursuing any legal
    action stating in a press release "it sucked actually let them
    have it,we couldn't get them to mow a straight line" (of interest
    Bolens admits the idea of their front suspension was garnered
    from a blueprint they latter learned was redrawn by a fella that
    worked in the mail room after he had spilled his coffee on the
    original and didn't want to get in trouble)
    How does it work: The TTB as Ford built it is a interesting
    suspension..first off one would like to point out that apparently
    they designed it to bend/move alot like a limp pasta noodle for
    Ride quality. So what we have is a axle that is two
    pieces...designed to flex considerably and move through a arch to
    promote nice Caddilac type ride in a truck. Now thinking about
    this one must ask themselves...why build a suspension to
    move....THEN as you do that, also design it so any time it does
    actually move it causes other issues? Apparently they realized
    that if they limmited how much the front flexed, they would have
    also cured the problems associated with it flexing. Much like a
    reverse engineered straight axle..you could simulate what
    happened here very easily with household tools if a understanding
    required looking at a scale model.
    Model exercise: Take a straight axle Dana 44 and sawzall or torch
    the axle in half about 2/3 of the axle length being one piece,
    and the remaining 1/3 the other. Now bolt on a barn hinge to
    facilitate ataching the two axle halves. This should give you a
    rough concept of the engeneering involved here and why Ford
    choose to keep it from moving *as much as possible* in the actual
    production built trucks.
    The simple design of the TTB also required a interesting dillema
    when it came to steering it. After all a tie rod can't be built
    of flexable plastic or something simular...and a tie rod that
    changes length was out..so without the technology for these two
    possible solutions to the need for flexable steering it was found
    that if they created enough links and connections in the
    steering...the natural slop would allow it to function if they
    kept it once again from traveling more than a few inches.
    Memo from Ford test driver: It exhibits a want to be driven like
    a hay wagon...with constant correction and high attention to
    direction it sure does ride nice.
    After many differant solutions were tried a think tank at Ford
    concluded that the correct way to market this axle was to seek
    the Gray Haired ladies and gents who were past fighter pilots and
    pin ball wizards thus a market segment in retired seniors with
    incredable reflexes, and excellant hand eye cordination were
    sought to buy these trucks.
    Over view: The above basically explains what the goal of Ford was
    regarding the TTB suspension design and some history behind it.
    One must marvel at the goals achieved as well as the engeneering
    required to build an axle with such a deviance from what was the
    industry standard.
    Alighnment specs:
    Caster: Changes every foot it drives *when adjusting read Fords
    special bullitan on personal mental health for the line mechanic"
    Camber: Specs here very with each truck and side to side on the
    same truck " Ford Service bullitan #21548 TTB Alighnment:
    dictates the following procedure. " Pretend to adjust,charge
    accordingly and smile and nodd and tell the tructh " tiz as good
    as it gets"
    Toe: To adjust this you must have a ridged platform..no wind, and
    please do not use a actual alighnment machine. A limp string and
    scotch tape being a better plan. Also something as simple as the
    earths gravitational pull can affect the toe settings. When a
    final adjustment is complete... do NOT move the truck or all your
    work will be for naught *Again consult Fords special bullitan on
    My personal experience with TTB is that even on a stock truck, keeping them aligned is difficult.
    Jack
    2007 2500hd, Max/Alli, Hawk FWC (the new explorer)
    Build thread: http://www.expeditionportal.com/foru...07-Chevy-Build
    2006 Jeep LJ Rubicon
    Build thread: http://www.expeditionportal.com/foru...006-LJ-Rubicon
    KE7NCK
  6. #26
    Join Date
    Dec 2011
    Location
    So. California
    Posts
    365
    Quote Originally Posted by Kermit View Post
    No doubt, those are great companies for TTB stuff, but they are the minority (and tend to be on the pricier side too). Many of the bigger-name products have narrow & flimsy axle brackets (which often stress the frame to the point of cracking), and the way they throw the angle of the steering linkage all catawampus because their drop pitman arms are too short (causing massive toe-in/toe-out bumpsteer) have led people to creating humorous stories like the one locrwln posted (thanks for the laugh too BTW lol).
    Alignment technicians unable to figure out how to change a caster alignment bushing when needed (or are too lazy to) and them telling vehicle owners "that's just how they are, blah blah" have not helped it's image either.
    I've messed with these suspensions for close to 25 years and have written a lot about them for the Ranger & Explorer crowd over on www.therangerstation.com, though virtually all of it can be applied to the F-150 & Bronco too. No doubt they have a unique personality, but they do perform well, ride great, and will stand up to a lot of abuse when setup correctly, all you need is a good understanding of them.
  7. #27
    Join Date
    Nov 2006
    Location
    Tucson, AZ
    Posts
    4,141
    Like anything, things can get blown out of proportion, then throw internet bashing and rumors on top of that. All the bad information tends to shadow
    the good. A TTB setup correctly will be just as strong as a SFA, and as smooth as IFS...best of both worlds, really. And every system has its' pros and cons.
    While not a TTB...that video of the beamed F100 shows how well that design works, and you can really beat on it.
  8. #28
    Join Date
    Jun 2011
    Location
    Ohio
    Posts
    523
    Wow. Can't believe there are actually people left that like the TTB 44.
    Allways appeared to be the absolute worst bit of engineering I ever saw/drove. (except for the even worse Econoline 350 whale tails. Murderous garbage)
    '08 Ford F250 XL
  9. #29
    Join Date
    Apr 2012
    Location
    Lemon Grove, CA
    Posts
    164
    having experience with both systems on the same vehicle, id say i prefer the solid front axle. the IFS that our little gmc jimmy came with did get the job done however it was of a very poor design and in order to run a tire of any worth, the torsion bars had to be turned up a bit. this made the 4wd basically useless as it would destroy idler arms as soon as the front wheels applied power to the ground, not to mention the inability to maintain any alignment specs. after many parts replaced, custom build idler arm and ok performance at best off road, we ripped everything out from under the front of the truck. in went a mid 90s high pinion D30 axle from an XJ mounted with a radius arm system and coil springs. now able to run 33" tires, the truck is absolutely amazing. its not too big so it fits in those places you like to go and yet it has the ground clearance and flex to go where you maybe shouldnt. it actually drives better on the road now than it did before thanks to less steering parts, joints and pivots with the solid axle and its steering.
    now on my HD duramax, the IFS works fine for what i use it for and fortunately there is enough aftermarket support for the known weak points that its plenty strong. i dont take it off the pavement very much as its just too long being a crew cab long bed and it just drags frame over the slightest obstacle...
  10. #30
    Join Date
    Apr 2010
    Location
    Casper, Wyoming
    Posts
    664
    I'd prefer solid axles. I have a D44 TTB in my 84 Ford 1/2 ton, and while it works perfectly (another vote for it), it also has too many parts and requires copious maintenance to stay working as well as most solid axles over time.
    I sure as sugar wouldn't swap it out for a solid axle, though. Too much expense and work for a negligible gain.
    But if I could choose a solid axle as an option on a new vehicle, I would. If I need something that rides nice, I'll take the car.
    Frank
    Civilized men sleep soundly because rough men stand ready to do violence on
    their behalf.
    - George Orwell
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
