Thread: Center console vents
  1. #1
    Join Date
    Apr 2012
    Location
    NM
    Posts
    33
    Default Center console vents
    Looks like the previous owner used one of those vent holders on the center console vents for holding the cell phone and busted both sides. Anyone know where I can find a replacement? Also, passenger window goes down but needs help going up. Can hear the motor turning but the window does not move. Would this be a fixable or replace type repair?
    Thanks
  2. #2
    Join Date
    Feb 2012
    Location
    Great Rissington, Gloucestershire, United Kingdom, United Kingdom
    Posts
    93
    For the window try a silicone pray
    1997 Pajero 3.5 GDI, 2" lift and 285/75/16 BFG Muds and a Sankey widetrack in tow!!
  3. #3
    Join Date
    Mar 2009
    Location
    Livermore, Ca
    Posts
    227
    Are you asking about a Montero, if so what year.
    You can fill in you signature with your truck information. It would be helpful to the readers to whom you are asking for information.
    Michael j
    TreadLightly! Trainer
    GrassCat III, 1994 Montero 5 speed stock ( for a little while ).
    GrassCat II, 1998 Montero with winter package. All the bells a whistles. Ran off with Hector.
    GrassCat I, 1991 Ran off with Justice R.
  4. #4
    Join Date
    Apr 2012
    Location
    NM
    Posts
    33
    Sorry, thought had included the info in my sig. It is a 96 Montero SR. As for silicone the window moves pretty easy with very little effort. Still think it needs the silicone?
    1996 Montero SR
    1985 Jeep Cherokee Chief Retired
    2011 Permobile C300 w/Tilt & Recline Wheelchair
    2010 Extreme 4x4 Wheelchair
  5. #5
    Join Date
    Mar 2009
    Location
    NorCal
    Posts
    3,288
    Quote Originally Posted by dave52355 View Post
    Well, it's either you try and lube it so it can move freely in both directions or you replace the window motor... Unless it was previously removed, I doubt it would be out of alignment since it does go down easily...
    1989 SWB Montero (3.0L v6, rear LSD), 33" mudders
    1996 Montero SR (3.5L v6, rear Locker), 35" mudders, 3.15:1 xcase crawler gears
    Build Thread: http://www.expeditionportal.com/foru...su-build-up...
  6. #6
    Join Date
    Apr 2012
    Location
    NM
    Posts
    33
    Well it looks like both driver and passenger front windows need work. So be taking a trip to the local salvage yard. No garage and its monsoon season. Guess I'll pull parts first. Got caught in a nasty downpour while trying to pull the drivers side window up we had it sideways in the channel.
    I know our local salvage guys don't have any Montaro's but hoping other vehicles/years parts will cross match. Can anyone tell me what matches up to the 96 Montero SR?
    We hit an 8 miles section of snot on our back road shortcut. Tail end was all over the place. My wife was driving. Last 2 miles we popped it in the 4x4. Had a great time!
    Thanks
    1996 Montero SR
  7. #7
    Join Date
    Mar 2009
    Location
    NorCal
    Posts
    3,288
    Only the Montero will fit. Check car-part.com for availability from most parts yards around the US.
  8. #8
    Join Date
    Apr 2012
    Location
    NM
    Posts
    33
    Another update: Driver's side is " fixed " Nothing wrong with the regulator or motor. The plastic clips that hold to the bottom of the window glass were busted off allowing the window to slip all the way down and out of the channel. Handful of nylon zip ties fixed it right up. Works like a champ. Tomorrow I'll attack the passenger side. Expect to find the same problem, hopefully. I don't suspect those clips are an Autozone purchase.
    1996 Montero SR
  9. #9
    Join Date
    Mar 2009
    Location
    Livermore, Ca
    Posts
    227
    Check your ASA program for the part number of the broken part. Then do a search on Google or whatever, to purchase them.
    Don't have the ASA program? Get it here http://www.mitsubishilinks.com/ along with the service manual.
    Michael j
  10. #10
    Join Date
    Apr 2012
    Location
    NM
    Posts
    33
    Thanks, had the Service Manual but not the ASA program. Very handy. Looks like the left front window regulators out. I've located a replacement but how do you get it out of the door? Manual's a bit sketchy on that.
    1996 Montero SR
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
