Page 1 of 4 123 ... LastLast
Thread: Headache/Bed Rack - Finished!
  1. #1
    Default Headache/Bed Rack - Finished!
    Here is a rack I've been working on the last week or so when I can. I've been building this in my head since before I got the truck and finally got around to putting it together as the toolbox I had on the truck was starting to fall apart. As I build the truck more and more, I want to gear this one towards more of a Expo/Zombie Apocalypse rig. For me, this requires two spares, extra fuel, and as much storage as possible. In all of this I also want to swap to a stack for the exhaust (have to be ready for those water crossings while eluding the hordes of undead).
    I only had to pick up the angle and the rest I had laying around from previous projects. The bed rails are 3/16" with everything else ranging from 14ga to 1/8". The rails and some small pieces were salvaged from a ladder rack that I have had no luck selling. I figured it was worth the $50 I paid for it in metal. Total weight of just the rack is probably in the 150-200lb range.
    One thing that always bothers me when expanded metal is used is the raw edge that almost always is left. Call it OCD or anal, but I had to frame it out.
    Tire mounts. Nothing fancy, just a cradle for it to sit in. I eventually want to run 39" range so I made the spaces big enough to fit just about anything in that size.
    Tie-downs are always a necessity, and the more the better. I didn't want big loops hanging off everywhere, so I picked up a handful of these rings and chopped them up. There is a 1/4 of a ring at each upright on the rails and half a dozen half rings for the spare hold downs and at the very rear of the bed rails. The 1/4 rings are perfect for regular ratchet straps or bungees.
    The rack itself is finished, but I still need to build the toolbox and stack. The toolbox is an older one I had picked up for my Tacoma and was in the middle of redoing when I totaled it. It's your normal truck style box. I'm going to cut one end off and spin it so the lid faces the rear of the truck. It will be in the big void next to the driver tire. The stack will be between the fuel cans and headache rack.
    Hold down for the fuel cans. The main bar holds them down while the angle to the side keeps the cans from being opened. The rear is hinged and the front will lock with a receiver lock.
    Every truck needs a good place to mount a hi-lift.
    Going to clean it up today and get paint on so I can get it on the truck in a day or two. I've got house chores for the coming week so hopefully I can get the toolbox done next week. If you look closely you may spy the stack material....
  2. #2
    Join Date
    Aug 2009
    Location
    Vancouver BC
    Posts
    157
    Well thought out........ No one will be stealing gas from those brackets...
    Eddy
  3. #3
    Join Date
    Apr 2012
    Location
    San Jose Ca
    Posts
    13
    Now thats bad *****, is this going on your GM? Any pics/Build up of the truck?
    Mike
    ECV 1849
    69' F250 Highboy 390/NP435/D24/HPD44/D60
  4. #4
    Yeah it's going on the Chevy. I have a build thread over on CK5.
    Got it painted today. Forgot to wet the garage floor before spraying it so I got to scrub the floor on my hands and knees to clean up the overspray.
    '88 Square Body Chevy CCLB - 12V Cummins - Denny T Stg II fuel pin, 3200 Gov Spring, NV4500, Divorced 205, Valair Kevlar/Ceramic Clutch, D60/14FF 4.10 Govloc, 37x12.50 BFG Baja T/A
  5. #5
    Join Date
    Oct 2008
    Location
    Whistler BC
    Posts
    1,960
    That is a fantastic rack. Very well thought out. Can't say I feel the same about stacks. They are a waste of space and a fire hazard in the box. But, a 12 valve in an older K truck is a nice touch! I will check out your build thread too.
    '98 Dodge 3500 CTD NV4500 complete with a crap load of goodies. "Bought, not built"
    '11 Rubicon Unlimited OME heavies
    '07 Adventurer 10T
    No kids, 3 dogs, many surfboards...
  6. #6
    I've been on the fence about a stack for a while now and wasn't going to do it. When I laid out the rack, there was a perfect spot for it, so I'm doing it. That and I actually feel bad about smoking out the people next to me.....most of the time.
  7. #7
    Join Date
    Nov 2011
    Location
    Columbia Falls, MT
    Posts
    142
    Can't wait to see it on the truck. Makes me kinda want to ditch my topper and build more on my own rack, lol.
    2005 Chevy Silverado Base 4X4: 4.8L, Auto, 4 door ex cab, short box, AEM Brute Force CAI, Flowmaster 40 SI/DO, 285's on 17 inch Helo's Summer and 265's on 17 inch Devino's for winter, custom made center console, custom engine tunes, custom headache rack, Kobalt contractors tool box, color matched grille and sport mirrors, HD towing mirrors, no power options but I got A/C!
    1992 Ford Ranger XLT 4X4: Needs a lot more done to it!
  8. #8
    Join Date
    Oct 2008
    Location
    Whistler BC
    Posts
    1,960
    I had a quick read of your thread on ck5. I may have missed it, but I assume this was some bodies project that they couldn't finish? It sounds like the motor was in, but the running gear needed a ton of work. You guys did a lot of work in a short time!
    '07 Adventurer 10T
  9. #9
    Yeah the guy I got it from started the swap about 4 years ago now. He had someone else doing the work though and when the housing market went bust, he didn't have the $$ to finish it (he's in construction I guess, didn't actually meet him). Anyway I had found it on CL in Phoenix and it looked like a basket case from the pics and description so I wasn't going to even bother with it. Well my buddy with virtually the same truck went and checked it out, told me I was stupid not to get it. All in all I could have made out better overall had I had the time to get a couple trucks, put them together, and part the rest. I'm happy with it though.
    At this point I've gone through just about all the major stuff and am working out the kinks. I was looking for a 96-98 dodge and was planning on swapping the drivetrain into a crew cab or suburban in a few years. I just happened to find it somewhat put together already so it allowed me to skip forward a bit. Basically I paid just for the truck what a clean crew would have run me and in total I've got about the same as what I would have paid for the Dodge, so I'm happy. My buddy built his over a year span and is a few thousand $ ahead of me. We had mine drivable in a week and then the next few months the big stuff showed it's head. Time=$ right?
  10. #10
    Join Date
    Apr 2012
    Location
    San Jose Ca
    Posts
    13
    Such a sweet rig, as well as the Dually ive seen it over on pirate a few times
    Mike
    ECV 1849
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
