Page 1 of 4 123 ... LastLast
Thread: What is NEEDED for a decent overland set up?
  1. #1
    Join Date
    Jul 2012
    Location
    Canada
    Posts
    7
    Default What is NEEDED for a decent overland set up?
    Hey folks as i've been lurking the forums for the last little bit I started to wonder how much is actually necessary for a decent overland set up. The vehicle in question for me is a mid 90's XJ (I don't yet own one) which i've picked for low cost, parts availability, out of the box performance and the reliability that only comes from using a modernized and glorified 1940's tractor engine. So how much ground clearance do you need, do you need heavier bumpers, do you need to beef up the driveline etc? I'm a mechanic by trade so i'm not afraid of the work, I just don't know where to start since I've never been more than 100 feet offroad in a vehicle I cared to be able to drive back so I defer to those with greater experience.
  2. #2
    Join Date
    Jan 2009
    Location
    Pasadena, CA
    Posts
    29
    You could drive that truck out of the showroom and over nearly any trail in US/Canada. Just make sure it's in good mechanical condition.
    Winch if you can afford it, since of all the things you can dump money on, it's the only thing that actually gets you UNstuck.
    Go through the axles, driveshafts, and steering, rebuild as necessary. If the rear is in particularly sorry shape and needs a complete overhaul, consider doing other upgrades (locker, higher spline count shafts, etc) while you're in there.
    Anything that adds weight reduces reliability, so only add armor and bumpers if you care for the sheet metal.
    Add the best tires you can, and you're good to go.
  3. #3
    Join Date
    Nov 2010
    Location
    Madawaska Highlands, ON
    Posts
    611
    A reliable truck that can deal with the added weight of all the equipment you will be adding is all you really need.
    2001 Jeep Cherokee
    1988 Jeep Comanche
    1987 Jeep Wrangler/YJ
  4. #4
    Join Date
    Jul 2012
    Location
    Canada
    Posts
    7
    My plan in my head before asking the question was some light skid plates (mostly stock from grand cherokee), frame reinforcements at the P/S box, a winch
    and some decent tires. Maybe I'll just clean it up and see how she goes and depending on my regular equipment load replace parts that fail with heavier duty components.
  5. #5
    Join Date
    May 2011
    Location
    Utah
    Posts
    1,884
    The skid plates from the Grand Cherokee ZJ do not directly interchange with the XJ. And the purpose of upgrading parts is so that you do not have a failure, especially if you are in the middle of nowhere without cell reception.
  6. #6
    Join Date
    Jul 2012
    Location
    Canada
    Posts
    7
    Yes I should have specified that when I say fail I mean fall outside spec, not catastrophic failure. So when I get play in the front end I use a heavier duty replacement rather than white box junk. I was under the impression that the ZJ plates could be lightly modified to fit an XJ looks like i need to do some more reading.
  7. #7
    Join Date
    Jan 2009
    Location
    Santee, CA
    Posts
    1,640
    You're on the right track. Take it out and use what you have, find out what the vehicle won't do that you want it to do and build it accordingly. Reliability is the most important thing IMO.
    I know far too many people that have built monster trucks because that's what they were told they NEEDED to get the job done. Keep in mind it usually takes three more modifications to make the first one work right. NEED a winch... going to require a bumper, which is going to require frame stiffeners for the uniframe, which will require stiffer front springs to support the weight, which will require longer shocks to meet the new ride height. It's a never ending vicious cycle that often results in an over weight pig that is miserable to drive on the road...all to get you ten miles down a dirt road to your favorite campground...oh, and your buddy is going to meet you there in his mini van.
    Coan Racing/Dust Junkies Racing, 2012 Baja 1000 Class 1700 Champs
    Dust Junkies Racing/Fat City Racing, 2010 Baja 1000 Class 1700 Champs
    Fat City Racing/Dust Junkies Racing, 2009 Baja 1000 Class 1700 Champs
  8. #8
    Join Date
    Mar 2007
    Location
    Whittier, Ca
    Posts
    589
    Default Stock XJ with good driving skills should be enough......
    On many of the trips I lead into the Southwest we have vehicles ranging from bone stock with street tires to highly modified rock crawlers. I always amused at how well the stock XJ's do, with a capable driver. On several occasions after, what would be considered a rather difficult climb or obstacle, the guys with the rock crawlers stand by and watch with amazement the stock vehicles doing just fine.
    Sometimes we spend thousnds of dollars on unnecessary equipment upgrades when it would be better spent on attending a off road driving skills class or spending some time with a qualified friend learning some "balance and traction" skills.
    I agree a stock XJ will take you on 75% of all off road trails and still provide you with a reasonable, dependable daily driver.
    Stock 1995 XJ on Heartbreak Ridge (Difficult rating)
    My 2 cents,
    Thanks,
    Fred
    Explorer 1
    "Of all the paths you take in life,
    Make sure some of them are dirt"
  9. #9
    Join Date
    Jul 2007
    Location
    Wp-GHC-WA-USA
    Posts
    1,364
    Quote Originally Posted by bob91yj View Post
    If that isn't keeping it real, I don't know what is.
    '05 Nissan Frontier Build Thread
    '08 Nissan Xterra Build Thread
    '09 Suzuki V Strom DL650 Build Thread
    You can read all the stories and watch all the videos you want, but there's no substitute for just getting out there and doing it.
  10. #10
    Join Date
    Apr 2010
    Location
    Norway
    Posts
    19
    Dont overbuild. I did that almost with my mercedes GD.
    Next overlanding trip, only change will be uppgraded suspension ( for better load capabillity ) and new, larger shocks. Tyres shall be MT , i assume BFG MT is best choice, i used to run GY MT/R, but they are not available anymore i belive; at least not in Europe...
    Decent amount of tools, and som recovery equipment, should be about it...
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
