Page 1 of 3 123 LastLast
Thread: We 'Canter'ed to the tip.
  1. #1
    Join Date
    Aug 2011
    Location
    Gladstone QLD. Australia
    Posts
    65
    Default We 'Canter'ed to the tip.
    We went for a trip to the tip of Cape York up along the "Old Telegraph Track" in my Canter. But first I better show how it was set up and some of what we changed. It started life as a work vehicle. --------------- Needed some super single wheels. Alan was able to supply some nice lite weight Alloy 16" rims, tyres are Kuhmo KL71 315/75-16 127Q rated.
  2. #2
    Join Date
    Aug 2011
    Location
    Posts
    65
    Next we went for a winch. Had to be good enough to be able to un-stick it if it gets well and truly bogged. Trouble is big winches are heavy on the front of Canters that already have trouble with the front suspension bottoming out, so fit it elsewhere! The 20,000 lb winch was supplied by Tigerz11, it weighs 75 Kg with cable. Under the back it went just over the tow bar so that it an be used out the back as well as the front. It was run around a couple of pulleys to the passenger side and along the chassis rail.--------------------------------------------
  3. #3
    Join Date
    Jul 2008
    Posts
    696
    What can i say, very nice wheels!!
  4. #4
    Join Date
    Nov 2010
    Location
    Canberra Australia
    Posts
    403
    No bias there Alan...
    My attempt to build something to go somewhere else...
    Canter4x4.com
  5. #5
    Join Date
    Sep 2007
    Location
    Central Nowhere, NA
    Posts
    4,382
    Tacoma - For Extended Overland Travels
    2012 FWC - The TARDIS
    Trip Reports - Travels with Hadley
    -Nathanael
    Large Format Photography
    www.KuenzliPhotography.com
  6. #6
    Join Date
    Aug 2011
    Location
    Posts
    65
    With the super singles comes the problem that the wider tyres just stick out of the front guards, so we needed to fit a set of front flares. These are universal rubber mudguard flares but to fit them you need to reinforce the plastic that they are fitted to. This was done by using 1.5mm sheet steel cut to fit in behind it. You can also see that I widened the rear of the front guards. ---------------------------------------------------------------------------------- Out of the front comes the winch cable and also a hard point to be able to run the winch cable to if we needed to double line it and also as a tow point. These are secured to a rail that fits between the chassis rail. The new tyres made a lot of difference to the ride on the front but to make it better we had new springs made for the front. These are 30mm longer from the center bolt back, effectively making the shackle hang back further and also giving us more clearance on the bump stop. This also then required new shock absorbers because we had to have more extension. Rancho 9000 adjustables were my choice.
  7. #7
    Join Date
    Nov 2011
    Location
    Victoria Australia
    Posts
    19
    Hey Aussie Iron,
    The truck is looking good, I'm hoping to get to the tip of Oz soon as well. Do you have any pics of how you routed the winch cable from the rear to the front of the truck? My winch is front mounted, love to be able to use it backwards as well.
    How about a few more pics of your truck on the run.
    Thanks
  8. #8
    Join Date
    Aug 2011
    Location
    Posts
    65
    We are getting there, time doesn't let me get the whole story out at once. Winch routing - I will have to take a few photos when I get some time. A slide-on camper was fitted to the back of the Canter so we went in luxury compared to what my sister and brother had on their Nissans. They just had roof top tents. The drums carry our spare fuel , Having the "truck" I could carry it as they didn't have the room. In the long run getting fuel wasn't a problem. My sister arrived at my place at Ambrose traveling from Coolum. Next day we left to go to Townsville where my brother lives. Spent some time there getting his vehicle finished as he had been inundated with work. We set of traveling via Cairns, Mareeba to Mount Molloy to sample one of their world winning best hamburger. From Mount Molloy onto the Peninsula Development Road and north towards Weipa finally taking the turn off to Batavia Downs reaching Bramwell Roadhouse. Here is where the Old Telegraph Track starts and I was promptly told that the Canter with my camper wouldn't make it. I just said I can always turn around and come back. The first crossing is Palm Creek and by all accounts is the easiest. Easy in and out. Well not this year by the seems of it. The first picture is the way in 2 metre drop down the other is the tail end of the way out after some has been filled up with dry fill. The bumper was in the mud on the drop down. The comments from the crowd were that this is going to be fun as it wouldn't make it and would have to be winched out as a lot of the previous vehicles had to be winched up. But up it went with not a care in the world to the cheers of the crowd. It would have been nice to have had a video of the climb But it didn't happen.
  9. #9
    Join Date
    Mar 2010
    Location
    Brisbane, Australia
    Posts
    268
    Cool pic thanks for sharing.
    Did you get stuck anywhere and was the width of the Canter a problem anywhere at all??
  10. #10
    Join Date
    Aug 2011
    Location
    Posts
    65
    We knew we were going to have to do quite a few water crossing all at varying depth and the Canter is fitted with extended breathers on both gearbox, transfer case and diffs. But not high enough so they were extended to the top of the head board to give 1.5 metre of clearance. The breather on the fuel tank was also raised to there. The standard air cleaner that was fitted was sealed on the drains on the bottom and grease applied to the seal on the base. No water entered the system at all which was good. I fitted new batteries that are sealed and just have breather tubes that can be closed of for a short period of time when going through a lot of water. ----------------------------------------- The people standing in the water are marking holes in the volcanic rock, some are big enough to drop the front of a vehicle in. Other crossings were gravel bottom.The water crossing of notoriety is Nolans Brook being better than a metre deep and about 25 metres across it takes a lot of vehicles every year. Most end up getting water inside. The first 9 metres is mud, the next 9 being moving sand then a climb up about 40 cm of soft sand and then easy climb out.This is normally taken by following the high spots to cross. Well after walking it, it was decided that the straight across track would suit the Canter. We put a cheap blue tarp down the front and let it fold well under then drove through with only a little bit wheel spin as we climbed the sand bank. Again not a problem and no water inside.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
