I am looking/needing to replace the valve cover on my '04 TJ Rubicon (4.0) with about 104,000 miles. I've sprung a leak from the valve cover & will be pulling the old one off over the weekend & at least replacing the gasket and torquing the bolts back down properly.
I'm thinking of "upgrading" to an aluminum cover, as I've "heard" that they can dissipate heat a bit more efficiently than steel, and also that they can help "quiet" some of the valve train noises....
Does anyone have any experience with this? Not sure it's worth the $$$ to replace the cover with aluminum, or keep the stock stamped steel one. Not sure if the factory one is "tweaked" at all (but there is a definite leak & from what I can see the gasket is shot), since I haven't had a chance to pull it off.
I've searched the forum a few different ways & haven't been able to find a discussion about this....
