Metcalf
The one I last saw was a 2003. I think it was around 2001-2007ish. These where the non-diesel, non-big block trucks, 2500 series only....so I think 6.0 engine trucks?
The axle is basically a slightly modernized 10.5" 14-bolt GM center section. The center section looks 'finned' but still has the bolt on pinion bearing support. It uses your standard GM 14-bolt gears with the 3 pinion bearings. The carrier is 14-bolt 30 spline...so any of the off the shelf lockers will work. Approx 67" wide. Factory disc brakes with a drum style parking brake. 8 on 6.5. Full floating. Factory gearing was 3.73 or 4.10.
In my opinion the perfect rear axle for a 1st gen Cummins truck. If I had factory 4.10 gears I probably would have broken down and swapped on in. Having to change the D60 gears opens up a whole new can of worms for me......D70 gears, lockers, rebuild, big brakes, 35 spline outers, etc
