Originally Posted by
GregB_00XJ
Any room under the bed of the truck for a custom made water tank? Lots of companies out there that build them to suit. You could mock one up from cardboard, rig up a filler tube and vent tubes, use marine fittings and even put a little pump in there. Just a thought, a friend had one made for his adventure trailer (25 gal I believe) and it is really well made and was not onerously expensive.
Easy to hang under there too with some steel straps and bolt it through the bed and or to the frame. Keeps the weight low, protected (skid plate if needed) and out of the way in otherwise wasted space. I have seen them here on the Portal before and the ones I saw were really well done. You could easily get 25 gal under there and lug a few Scepter water jugs on the bumper in carriers for the rest.
Just a thought.
