Any feedback on the C rated Duratracs? That's what I'm considering. The Es sound a bit much (max load: 2200lbs vs 3000lbs per tire) for my 4500lbs truck.
2001 Pathfinder SE 4x4: AC 2" lift, 31" Goodyear Duratracs, ARB rear locker, RRO super sliders, diy skidplate, WARN manual hubs, Rola vortex roof-rack, diy storage platform, 2m/70cm and CB
1998 328i - daily/autox/trackdays
2004 Honda ST1300 - touring
2003 Ninja - fun
Russell - The C rated DT'S are 2 ply. So a thinner and possibly weaker sidewall. On the flip side, you would get more flex out of them on trails and when airing down and a softer, more cushioned ride on-road.
I don't have a set yet, buy I have been researching them for few months now*
*I am not a scientist, YMMV.
- Chris
Chris
2004 Tundra DC 4WD
Thanks Falkon. I was hoping someone with the C rated (2ply) Duratracs (or others) would chime in because I've heard rumors that the 2ply tires suffer from frequent punctures and sidewall damage...but it's always hear-se not a direct account. I wonder how many AT tires are 2ply and work ok for normal offroading.
2003 Ninja - fun
I had 10-11 32nds of tread left on my Duratracs after 59,000 miles on my Tacoma (265/75/16 load range C). They were getting noisy and a little rough, and their grip on wet pavement had decreased somewhat, but they were still going strong.
EDIT: I should have mentioned that their wet weather performance was exteremely good to begin with, and even after it had decreased slightly with wear, they were still very good.
Ryan
2008 Tacoma
1968 Camaro
"I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them" - Thomas Jefferson
"We all dream of a world filled with sunshine, peace, and happiness. The problem is that half the people think this sounds like a wonderful place to live...while the other half think it sounds like a wonderful place to pillage."
Lots do. But normal offroading it only takes one sharp stone you don't see or one root you slide into a little on a forest road to kill a tire. I've shredded a 3 ply tire on nothing more than a dirt road and a tree root in low light. I personally buy the 3 ply because its just one more layer. It may make no difference, but peace of mind is part of my enjoyment, and so if I feel better about it, its worth it to me.
99 4runner- "Baby Beast 2"
General Recreation Vehicle
I'm on my second set of Duratracs, got around 55K miles on first set. I have been all throughout Utah(mountains, desert, slickrock, etc.) and have never had a problem with them. They are also great in winter too.
-Devin Baumgardner
'07 FJ Cruiser
Have a set of C rated on my xterra, have about 18,000 miles. They ride well, air down well, and seem to be wearing well. I draw a chalk line across the tread and drive forward to see what the pressure should be for different loads to keep the tread wearing evenly from edge to edge. Usually I add a little for better mileage, because when I air down it wears the edges more.
Rotate any set and they will last longer too. But they have been great in the snow, even pulling a loaded enclosed two place snowmobile trailer through 10 inches of fresh snow up hill. The only issue I have, which would happen with any MT, is that when I put chains on them the chain falls between the tread blocks on the edges. It would be worse though with many other MT tires, which would almost literally swallow the chains between all the blocks rendering chains useless. At least the middle of the tire tread on the DTs keeps the chains touching the ground.
1999 GMC K2500 BURBAN, NAVISTAR enhanced 6.5 td aftercooled, dual alt's, PSC p/s pump w/HD cooler, redundant FSD's, HEATH program, turbine/downpipe wrapped, 4" SS exhaust, real time OBD2 data logging w/device controller, EVANS waterless coolant @ zero (0) psi & 135 gpm pump, 4L80e w/kevlar and premium steel w/cryo treated input/output shafts running @ 100 deg. F & 140 deg F towing, all synthetic fluids, AMSOIL bypass system, MileMarker hydro, dual fuel tanks, and on and on, questions PM me.
I have load range C 245/75/16 DuraTracs on my 2002 Tacoma. I go four-wheeling quite a bit in the mountains of northern Utah and occasionally in Moab. During more than two years and about 8K miles on these tires, I've seen only a couple of minor sidewall cuts -- nothing that goes deeper than the surface rubber. I'm mindful that these tires don't offer the best sidewall protection, so I'm careful about the lines I take while off the pavement. When I intentionally use the sidewall lugs for traction, I do so only on dirt or other relatively soft surfaces.
These tires offer noticeably better traction on virtually any surface I can think of than other tires I've had on the truck, including first-gen MT/Rs and BFG All-Terrains. Both were load range E and also in the 245/75/16 size.
