Originally Posted by
gjackson
With the right parts and a ground up, you can make just about anything you want. If you like the series interior better, you could easily put that on a coil sprung frame with a 300tdi or a td5 with the 5 spd tranny. Only problem I see with the series interior is fitting AC which you will get with a td5 and is an easy option for the 300tdi.
Just figure out what you want first as you will have to make sure that the frame has the appropriate engine/drivetrain mounts as well as suspension mounts.
From what you are looking for I would say it would be easier to start with a 110 frame, but certainly not impossible if you started with a 109.
cheers
