Project Bronco Trailer
hammer
Got the roof sides welded up. 2" angle braces the bottom on the inside, then a piece of 1 1/4" x 1/8" flat bar runs up between the window's on the inside. All welded up.
Also removed the front roof brace out of the front section of the roof that I had cut off. Cut the brackets out of it as well. Screwed the brackets in with sheet metal screws and then bolted the brace into the new roof.
Roof brace;
Inside driver's side;
Outside drivers side;
Next steps for the roof is I have to remove it flip it over and weld up the rest from the inside.
Got the trailer back from a local off road shop that I bartered with to get some tube work done. Rear wrap around bumper with receiver and a couple steps off the front.
jgrillz94
