Page 1 of 2 12 LastLast
Thread: 2009 Husabergs!
  1. #1
    Join Date
    Nov 2006
    Location
    Tucson, AZ
    Posts
    2,020
    Default 2009 Husabergs!
    Check out the new motor....flipping cool!
    Hard facts:
    Facts Husaberg 450FE 2009
    Engine 1-cylinder 4-stroke SOHC, 4 valve
    Displacement 448.6 cc
    Bore/Stroke 95/63.4 mm
    Compression 11.9:1
    Starter Electrical, 6 Ah
    No of gears 6
    Fuel management Keihin EMS with EFI
    Clutch Multi disc, wet, Magura hydraulic operated
    Frame Perimeter Chrome-molly
    Sub-frame Polyethylene (plastic)
    Handlebar Tapered aluminium
    Suspension front WP USD 48, fully adjustable
    Suspension rear WP PDS 5018 DCC, fullt adjustable
    Susp travel Front 300 mm, rear 335 mm
    Brakes front/rear Two piston/ single piston, Brembo
    Wheels front/rear 1.60 x 21"; 2.15 x 18" Excel
    Tires front/rear 90/90-21"; 140/80-18“
    Steering angle 63.5°
  2. #2
    Join Date
    Sep 2006
    Location
    Sunnyvale, CA
    Posts
    1,129
    Wow, nice and compact. Why do they have to put the kicker on the left.
    My 06 Tacoma with ATC Bobcat
    Courage is resistance to fear, mastery of fear - not absence of fear. - Mark Twain
  3. #3
    Join Date
    Nov 2006
    Location
    Tucson, AZ
    Posts
    2,020
    Quote Originally Posted by slooowr6
    That is the kickstand (I think that is what you are referring to) No kickstarter, E-Start only. The 2008 KTM SX's are that way.
    The 'Bergs now, do have the kickstarter on the left...just a different way of doing things. If I remember, the old Cagiva's were on the left also. Plus the KTM 640.
  4. #4
    Join Date
    Sep 2006
    Location
    Sunnyvale, CA
    Posts
    1,129
    I thought that black line on the left is the kick start. Woo, e-start nice!
  5. #5
    Join Date
    Nov 2006
    Location
    Tucson, AZ
    Posts
    2,020
    More shots of the motor, looks like they are using the topend off of new KTM motor.
  6. #6
    Join Date
    Nov 2006
    Location
    Tucson, AZ
    Posts
    2,020
    That is either wiring harness coming off the stator or the hydraulic line going to the slave cyclinder for the clutch.
  7. #7
    Join Date
    Nov 2006
    Location
    Flagstaff, AZ
    Posts
    327
    FE models from '00 and up had E-start anyway.
    Plastic subframe? With the way I ride (fall) that thing will go crack in about 15 minutes. EFI will be nice though.
    1999 Isuzu Trooper - The Trooperscooper II (Rolled, need a truck)
    2004 Husaberg Fe450e - The Blackberg
  8. #8
    Join Date
    Feb 2007
    Location
    Arlington, MA
    Posts
    32
    Nice looking. And no worry about the shifter cracking the case if it goes down on the left...
  9. #9
    Hltoppr's Avatar
    Hltoppr is offline Overland Training Alumni
    Expedition Portal Moderator
    El Gringo Spectacular!
    Join Date
    Aug 2005
    Location
    Northern Arizona
    Posts
    3,189
    Wow...nice...
    Too bad it's too much bike for my riding skill!!
    -H-
    Andrew
  10. #10
    Join Date
    Nov 2006
    Location
    Tucson, AZ
    Posts
    2,020
    Quote Originally Posted by Hltoppr
    Wow...nice...
    -H-
    Oh, it has to feel like a toy compared to your GS.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
