blue bomber
After doing the cast iron clutch master upgrade. I decided to do my brake master as well. I used a 1986 Lincoln town car. Same piston diameter and bolt pattern as the girling variety. It fits in the same opening in the dual circuit cut fender. A couple of simple mods and my new $22.00 Bendix brand, made in USA cylinder was installed.
New vs old
The piston on the girling is flush and the Ford has a pocket.
Cut a grade 8 bolt to make up the difference in pushrod contact point
Adjusted pushrod for clearance. Making sure the piston can fully return to the snap ring.
Seventh try at making new flares!!! Least favorite job!!!
Plumbed and bled.
Like its supposed to be there.
Tapatalk sucks, sent from Matthew's IPhone
New vs old
Plumbed and bled.
