1987 Scamper camper truck pop up camper Roof repair
Olyellen
Hello All,
Realized my roof repair goes deeper then I thought. I need to remove it to rebuild. In order to do so I need to remove my canvas, which is still in good condition. Does anyone have any information on this process. In a few corners the screws attaching canvas to roof are very hard to get to. Thanks
Zmanfj40
There is a process to removal. Raise the roof, remove the 4000 screws from the canvas. Basically fully raised removes the tension from the internal bars inside the tubes. Once fully raised remove the hardware from the corner mounts( there may be tensionand this is where it can springa hole throughthe roof so be careful) ,then the two bolts up front. Now cover the corner brackets with carpet to protect your roof from damage, and slide a 2×4 in-between the tube and the roof,on the front put the 2x4 on the canvas and let the roof rest on that when lowered. Lower roof system and have 4 people to lift roof off using the 2x4s to pick up.
Sent from my SM-N981U using Tapatalk
