1987 Vanagon Westy weekender possible trade
Ar_Davis
I have decided to sell my long time project 1987 vw vanagon. Over the last 3.5 years I have brought this thing back to life and need someone to take over and finish it out. The only reason I’m selling is because I want to build a full size van for my growing family and to take to mountain bike races as a support vehicle. I absolutely love this van but it’s time to part ways.
In the ad I will be brutally honest in hopes that if someone is buying out of state they know exactly what to expect when they see the vehicle and not receive any surprises when they take ownership.
I am asking 15,000 for the van. It will come with a 1992 svx motor, harness, ecu, and reversed coolant manifold. I also have a good very straight syncro tin top builder that I would sell if someone made a high enough offer with the purchase of the vanagon. I will not sell the syncro without selling the vanagon unless you make me some crazy high offer.
Here is the work that has been done to the van since I rescued it from a field in Arkansas
May trade for 4x4 ford van or powerstroke van or possibly the right class b.
Engine and transmission:
-Rebuilt 2.1 WBX with AMC heads and a go westy High volume oil pump (estimate 10k miles since rebuilt)
-New thermostat
-New Temperature sensors
-New Ignition coil, plugs, plug wires, cap and rotor
-New Go Westy AFM Filter cable
-New fuel lines
-Cleaned and resealed injectors
-New oil pressure switches
-VDO Oil pressure gauge
-Go Westy Temperature gauge correction resistor
-New Air filter
-New intake boots
-New starter
-Go westy hard start relay kit
-New axle seals
-New CV axle boots
-New motor mounts
-New transmission mount
-New Battery 6mo ago
-New O2 sensor
-Resealed fuel tank and installed new filler neck and cap
-New fuel sending unit
Interior & Body
-Smittybuilt awning with GoWesty Awning mounts
-The old rust is a spot on the windshield seal which is a common problem. The rest is rust free.
-New “Hardwood” floors in main area
-New stow-n-Go seats that fold flat
-LED gauge lights
-Go Westy gauge foil replacement
-Dash mounted VDO Oil pressure gauge
-Entire interior was gutted to cleaned and reinsulated
-Tinted windows 15% all the way around
-Homemade curtains using what was left of the originals as a pattern
-LED headlight bulbs
-New headlight adjuster kit
-New Busdepot 3 window tent
-New pop top seals all the way around
-New skylight seal and lift mechanism
-New various shifter parts although it is time for an adjustment or to replace some of the bushings
-Gowesty ABS door panels
-Switch panel installed by driver’s seat to control power ports in rear and exterior aux lights
-Aux fuse panel under driver’s seat fed off aux battery
-Homemade headbanger cabinet, Van came with AC which was partially removed but still have
-New ignition switch and tumbler
-Go Westy window insulation kit
-I still have the original rear bug screen.
Suspension and Brakes:
-New ball joints, upper and lower
-New inner and outer tie rods with steering rack boots
-New brake hoses
-New brake pads
-Repacked front wheel bearings
-New rear wheel bearings
-General grabber at2 on Mercedes clk320 wheels
-New steering coupler discs
-New shocks front and rear
-flushed brake system
-New calipers
-New steering rack bushings
Now for the bad, keep in mind this is a 30 year old van and if it was perfect I would be asking much more.
-It needs paint and body. There is previous damage in the passenger rear that was not repaired correctly. The nose will need some straightening as well.
-The drivers window switch for the passenger side does not work in the up position. (the passenger switch works fine)
-It has vanagon syndrome but is still reliable. It will just buck occasionally, it didn’t do this till I installed the AFM cable. I believe it is still caused by the AFM itself.
-The suspension bushing have not been replaced recently, they aren’t worn out but could use a refresh anyway.
-The drivers side door and rear hatch electric locks don’t work. As well the rear hatch tumbler is sticky at times but works.
-The headlight dipswitch only works in the low position
-The dash heater motor stopped working at the end of the winter, I haven’t looked to see what the problem is yet.
-Some of the cupholders in the back are broken
Here are a few problem I plan on addressing in the next few weeks.
-The brakes I just installed are squeaking, I am going to try a different pad and replace the rotors.
-Last trip I took the Temp started acting erratically and would not work then would read low and stop working again. It made the 300 mile trip without issues
-The new starter I have likes to stick occasionally, I plan to replace it with an OEM and get rid of the parts store reman on there now.
https://photos.google.com/share/AF1...?key=RUFNWjhTR2JVTkJBNU1JcVpxSk5uRFROalFHTEpn
Ar_Davis
Bump. Fixed the temp gauge and vanagon syndrome.
Throw some ford van trades at me. I would take trades and cash.
Sent from my SAMSUNG-SM-N910A using Tapatalk
Sno Dawg
Sno Dawg
I have a VW Westfalia sink cabinet that is an exact fit for this Vanagon. Please send my info to the new owner and I can hook them up with the cabinet and sink.
Sorry to hijack your thread - GLWS
Jeff - Sno Dawg
jgrillz94
