1999 Cherokee XJ - Trail/Expedition - Well Built
NOTNSUV
1999 Jeep Cherokee XJ Sport
NE Nevada (equidistant from Reno, Salt Lake City, and Boise, ID). Can help transport - negotiable.
144k mi. $11,000 obo
More pictures on request. NEVER in the rocks, trail rig only and seldom driven. Very capable!
4.0L I6
4-port Neon injectors
Spectre cowl cold air intake
New Battery
New sealed TPS (throttle position sensor)
Starts/runs/drives excellent.
Auto trans (4spd OD)
4.56 Diffs
Complete rock guards on both diffs, spring guards. These are the diffs pictured on the cover of Eric Zappe’s High-Performance Jeep Cherokee Builder's Guide 1984-2001.
https://www.amazon.com/High-Performa...SIN=1613250657
Yukon Axles
Warn Hubs
4-wheel Disc Brakes
ARB Air Lockers front & rear
ARB compressor (new)
Professionally wired with common relay box mounted with compressor passenger side rear.
Vision X offroad lights, etc on central switchpanel (ashtray).
Compressor and ARB Locker switches installed ‘in-dash’
Complete OME 3.5” lift with new front coils and rear spring packs.
Daniel Stern headlight upgrade. Larger gauge wire and C-I-B-E lamps (see-b-a)
Less than 1000 miles on entire suspension front & rear.
AdjustableTrack bar
Sway bar disconnects
Steel D wheels (black)
5 NEW BFG KM2. 33/10.50. Less than 500 miles on tires & wheels.
Straight and clean in Black. Minor pin-stripping.
Rusty’s Offroad steel front fenders (w/flares)
Rusty’s Offroad steel rear fenders 3/16” with flares.
JRC rear tire carrier (new KM2), fuel/water carrier, hi-lift mount, CB antenna mount.
JRC transfer case skid
JRC gas tank skid.
JRC Rock Sliders.
AJ’s PhatXJ Winch Bumper.
Warn 9000 winch with new steel cable.
Trailer wiring complete (4-pin)
Very minor surface rust on roof. All else is clean.
Excellent Grey cloth seats
Camo front seat covers. Seats excellent
Excellent floors & Carpet with liners
LED interior lights
CB Radio. 2 antennas (SWR tuned)
New Driver's Door master power switch.
Power windows, locks, mirrors all work A1
Shortcomings/needs attention: No windshield washer bottle. All else is in place but had to remove WW for Rusty's fenders and cutout OEM fenders. I have several bottles to mock up a WW just haven't gotten to it.
NOTNSUV
AUTO
How did I not put that in there. Good catch. Will try to edit in. Speedo has been calibrated with gears/tires.
I don't remember codes for transmissions and xfer cases but it's OEM stuff throughout (except upgrades of course). I'll grab the numbers if needed.
Thanks.
79CHKCHK
Any more pics? The rust you mentioned on the roof, any other typical rust spots (under carriage, bottoms of doors and door jams, rear hatch, axles/suspension), engine bay, interior?
NOTNSUV
Rust is minimal or non-existent in those spots. I'll try to get more pictures today now that the weather is warming. And this XJ is DRY underneath.. no leaks, none.
NOTNSUV
Front door bottom. Dirty not damaged. Rust Free.
Guess I'm not impressing with it being dirty. I'll wash and clean everything if you get serious. It really does clean up nicely.
