derektshaffer
2004 Sienna AWD Camper Van Conversion. Runs and drives great! I've used this van to live in and travel around the country for the last year. I wouldn't hesitate to take it on another trip but I decided to buy a larger van to convert. Its AWD with a 3.5" lift kit and has new, all terrain tires so it will take you anywhere you want to go! Includes thermoelectric cooler and solar charge controller, plus wiring for the solar panel and battery connection. Also includes 2" Westin hitch and an extended roof rack. LED headlights and fog lights. All interior lighting is converted to LED. On the inside it has lots of storage and a pull out bed with memory foam mattress that folds up into a couch. Lots of storage under the bed and couch as well. I made window coverings out of reflectix for the all of the windows, this allows for insulation and complete privacy when camping. I wasn't planning on selling the van so I installed a lot of new parts over the last year.
-New struts up front and new shocks in the rear
-New radiator
-New rotors and brake pads on all four wheels
-New outer tie rods
-3.5" lift kit from journeysoffroad.com
-Timing belt, water pump, and power steering pump replaced at 200,000miles
-Flushed transmission and refilled /changed transfer case and rear differential fluid
-New wheel bearing on all four wheels
-New cv axles in the front
-Replaced driveshaft and U-joints from a donor vehicle
-Hankook Dynapro at2 245/65 r 17 tires, only about 5,000 miles on them
More pictures
-New radiator
-New outer tie rods
More pictures
