philjeeper
2006 Ford E350 Box Van 2wd
5.4L V8 with 5 speed 5r110 Automatic Transmission
205k miles
Transmission Rebuilt @188k
235/85r16 BFG All Terrain tires near new
New Shocks, Suspension bushings, belts, and brakes front and rear
Hellwig RV rear sway bar
FRP Box Construction
Seatbelts for 3 passengers
Also have Ford passenger van rear bench seat with mounts and seatbelts that can be included
Tinted windows all around and all rear windows slide open with screens and window coverings to insulate when hot or cold
2 roof vents with Fans
Huge Storage space over the Cab
Walls and Ceiling are insulated with foam board and covered with cedar tongue and groove
Floor is 3/4" thick rubber mats
Large locking tool box
Sink with hand pump/ 14 gal. freshwater underneath sink
Custom Aluminum Bed frame to hold Full or Queen size mattress
Bed raises and lowers utilizing E-Track brackets along walls/lifts all the way against ceiling for max cargo space and can be easily removed
Can fit 6 mountain bikes or 3 dirtbikes underneath bed with room to sleep above
E-track along floor in rear to tie down and secure loads
Custom Aluminum Rear Doors
Side Entry door with screen door
Included but not installed:
Dana 60 Front Axle with matching gears for 4wd conversion(leaf spring axle for U-Joint 4wd Conversion) complete with steering, brakes, sway bar
House battery with mounts/solenoids/wiring to charge from Van battery
Solar panel with regulator/ fuse box to power accesories
LED interior strip lighting with dimmer switch
Must see to appreciate!
18k obo
205k miles
18k obo
