2nd post here, great site with lots of great info. Thank you!
On to my issue... The AC compressor seized up in my Monty, so I had it replaced. The tech who did the work didn't take the rad out to replace the condenser, he just unbolted the bottom and pulled it back, which put pressure on the lower elbow on the rad and caused it to start leaking. So, I made them replace the rad as well.
Now there is an issue with the compressor cutting chunks out of the lower rad hose. There is almost no clearance between the 2, maybe 3 or 4 mm, which disappears when the system gets up to temp.
So my questions are: would there be a lot of difference between a non oem and oem lower rad hose, sufficiently so as to have more clearance between the compressor and the hose?
I did ask the shop for the part number of the rad they put in, and he said it was 43-1387. I can not any reference between this number and a mitsu rad number. So I can't tell if it is the correct rad for my truck.
Also, does anyone know of any good techs in the golden triangle area of TX, Beaumont, Port Arthur, Lumberton who know how to work on these trucks? I have had very bad luck thus far in the area. Or alternatively, is there anyone here living near the area who knows how to work on them and would be willing to help me? For suitable compensation, of course!
TIA for any and all suggestions/advice!
MJ
MJ
