New lights. I purchased these to measure off of while designing a custom bumper, and ended up going a different route. Lights have never been powered up, and come with all mounting hardware. You will need to supply your own 3-pin GM weatherpak connectors to tie into the installed connectors.
Also includes one round bezel. Extra bezels can be purchased from Baja Designs.
Driving Combo lenses installed. You can purchase other lenses from Baja Designs.
Paid $400. Asking $325. Free shipping to CONUS.
Located in Flagstaff, AZ, USA
Description:
The XL Sport makes it easy to light up your world in style, with the perfect combination of affordability and performance. The XL Sport LED light utilizes our trademarked High Speed Spot reflectors providing for a longer beam pattern. The XL Sport provides the same top of the line performance and aesthetics you expect from BD in an affordable solution. All Baja Designs LEDs are backed by a 30 Day Satisfaction Guarantee & Limited Lifetime Warranty for the ultimate in purchase protection.
Note: A Skene dimmer must be purchased separately to enable the high/low feature.
Baja Designs Features:
Satisfactions Guarantee – 30 Day Money Back
Guarantee
Limited Lifetime Warranty – Complete Purchase Protection
uService® – Replaceable Lenses And Optics
ClearView® – All The Light, Right Where You Need It.
MoistureBlock™ – Waterproof, Rain Proof, Submersible
CopperDrive® – Only LED Driven At 100%
5000K Daylight – Less Driver Fatigue, Natural ColorSpecifications:
Lumens: 2,260 Utilizing 4 LEDs
Wattage/Amps: 20W / 1.4A
Dimensions: 4.43" x 3.65" x 4.43"
Weight: 2.45 lbs
LED Life Expectancy: 49,930 Hours
Front Lens: Hard Coated Polycarbonate
Housing: Powder Coated Cast Aluminum
Bezel: Billet Machined Aluminum
Hardware & Bracket Material: Stainless Steel
Exceeds MIL-STD810G (Mil-Spec Testing)
Built-In Overvoltage Protection
IP69K (Waterproof, Submersible to 9ft)
IK10 Compliant (Mechanical Impact Testing)
Includes:
Patterns:
Driving/Combo: Maximum trail coverage in a single light. The Driving/Combo pattern is equipped with both Wide Driving (44°) and spot (6°) optics to provide you with a smooth blend of light for both near field applications and distance (Lighting Zone 3)
Description:
Guarantee
Weight: 2.45 lbs
Includes:
- XL Sport LED Light
- Mounting Bracket
Patterns:
