Coleman Gemini PowerPack - Alternative to large propane tanks
#1
I've been using a Coleman's Gemini PowerPack for a few years now and they work really well. It basically connects two 1lb disposable bottles to essentially create a 2lb propane bottle. With this setup I've been able to double the run time on my Buddy Heater and also run my Camp Chef portable Fire Pit without a large propane tank. The form factor is a bit large although you could possibly store two bottles and save a bit of space but even then, it's still a bit bulky to pack. I recently discovered that I could detach the plastic case, saves a TON of space!
Also as a side note, Front Runner Wolf Packs are perfect for holding a bunch of 1lb propane tanks.
#2
Depending on the rig I'm using, I carry an 80gal tank, or 1-2 BBQ bottles at 20# as the tanks that get refilled when I buy gas, last time at $1.62 per gallon or less than 40¢ per pound.
I decant from there into 13#, 5# or even 1# bottles, but never those disposable ones when travelling, only the DOT certified ones designed to be refilled.
#3
Unless you are refilling the 1lb tanks(and yes, some expo guys will get their panties in a wad over that idea) just get a 10lb tank or two and an adapter hose to run to your stuff that takes 1lb bottles.
#7
yeah you need a deep freezer and a warm sunny day to get em anywhere near full, not really something you can do in the field.. brand new bottles I bought that season I could refill once, any bottles with any age on em the valve never sealed off perfectly and they were empty when I went to go use em.. the condensation that forms on the bottle rusts out or otherwise contaminates the valve/threads PDQ.. really most valves only get exercised once, when plugged in to the device and then ran til dry.. maybe they get used a few times, but none are designed for repeated use.
