Darwin
Trying to decide going with a Webasto dual top evo or Espar hydronic for heat and hot water. One of the issues is I believe Espar says the unit must be mounted outside, which I would rather not do since I am planing demountable box mounted onto a flat bed. I would NOT be tying into the vehicles fuel tank and instead use a marine 5 gallon tank, again because the box will be demountable.
The Advantage I see to the Webasto dual top is that I know people some mount them inside the cabin, example Earthcruiser and XP campers both do this. The Issue I have with the Webasto though is that it automatically drains when the temp drops so it must be kept running all the time in freezing temperature thus using more fuel. I know Rixen makes a full set up using an Espar hydronic heater but their install intent is to be mounted outside and below a sprinter.
Anyone have experience with either of those two units?
Sincerely,
Darwin
Sincerely,
Darwin
