SOLD - Ford 4x4 7.3L Powerstroke with flatbed and Northern Lite Camper
ToTheMoon
Link to additional photos: https://drive.google.com/open?id=12y9WY2BdIbCY845pY8ZlHckTEMbVchf9
Greetings! So what’s going on here is my best version of a custom, compact, 4x4, all seasons adventure rig. I took a four wheel drive 7.3L Powerstroke diesel truck, swapped the stock bed for a lightweight aluminum flatbed, increased the storage with aluminum boxes, and dropped on a lightweight/insulated fiberglass camper. The combination of a powerful diesel engine, aluminum bed, and fiberglass camper make it a more fuel efficient and capable rig. I am the third owner of the truck. The original owner was a mechanic at a Ford dealership, and the second owner just used the truck to get around his property, that’s why the miles are low. It’s not brand new…so there are some minor signs of cosmetic wear and tear on the truck and camper. The truck runs great with no mechanical issues. Asking Price: $34,000 OBO
The Truck: 1994 Ford F-250 XLT 4X4 7.3 Powerstroke Turbodiesel
-158,300 original miles
-Manual transmission
-Clean title
-Smogged and registered on 8/15/18
-Goodyear Wrangler Duratrac LT285/75R16 tires rotated every 5,000 miles with 90% tread left
-K&N air filter
-4in exhaust
-Solid front Axle
-Dual fuel Tanks
-Tinted windows
-Cruise control
-Power windows
-Biltstein shocks
-Locking hubs
-New Front End (all new tie rods) 12/15/2016
-New Interstate Battery 12/15/2016
-New Fuel Lines 12/27/16
-New Oil Pan 12/27/16
-New Starter 1/20/2017
-New Fuel heater and filter 2/21/2017
-New Glow plugs and glow plug Harness 5/4/1017
-New Rebuilt rear brakes 12/18/2017
-New Catalytic converter 8/15/2018
-Aluminum Flatbed mounted with custom brackets
-Aluminium Storage boxes
-Locking Rotopax spare fuel(3gal) and water(1.75gal) tanks
The Camper: 1993 Northern Lite 6’10 Lite series truck camper
-Two piece molded fiberglass shell
-1” R6 block foam insulation
-1.8 cu ft 3 way fridge
-3 burner gas range
-Range exhaust fan
-20lb Propane tank
-14.5 fresh water tank
-Roof vent
-Screen Door
-Under 1,000 lbs dry
Work I’ve done:
-New Flooring and counter top
-Upgraded all lighting to LED
-New interior paint
-New custom water resistant upholstery
-Hypervent underneath mattress for ventilation
-New paneling in bed area
-Custom slide out cabinets and range cover
-Removed furnace and installed wood stove with rotating stove pipe
-Tee’d off gas line with quick connect fitting to Buddy propane heater and exterior gas grill
-2 Goal Zero Boulder 200w solar panels tied into 2 Goal Zero Yeti 400 batteries
-New Torklift springloaded turnbuckles
-Exterior Auxiliary simple solar hot water pipe
-Re-sealed exterior seam with new calking, screws, and screw cover
-Re-sealed and patched roof and it is completely water tight
I'm located in Reno, NV, USA Please feel free to email me with any questions timeddy1080@gmail.com
Thanks for looking and happy trails!
IMG_7356.jpgIMG_7401.jpgIMG_7377.jpgIMG_7378.jpgIMG_7380.jpgIMG_7384.jpgIMG_7391.jpgIMG_7388.jpgIMG_7398.jpg
Herkjerk
I'm in Sacramento and would love to come check it out! How much are you asking?
Sent from my SAMSUNG-SM-G930A using Tapatalk
Rinzlerz
