hobietony
2" steel wheel spacer. Can be used for an offset spacer on SRW vehicles, or as a spacer between the duallies on DRW vehicles. 8x170 bolt pattern, fine thread studs, with a hub-centering lip. Should fit '99-'04 4x4 Ford F250/350. Used, so some surface discoloration in the pictures. Cheapest I saw on a Google search for STEEL spacers was $310, so $100 pricing is pretty firm. Its heavy, but will fit in a flat-rate box. Add actual shipping as required. I check text much more frequently - five2zero, 95five, 2seven6nine. Tony. Thanks!
