BigSwede
The Credible Hulk
I am mulling over a myriad of options for powering devices overnight, and would like some opinions. First of all, my situation: I use a CPAP "snorkel" for sleeping (sleep apnea). The CPAP company tells me the device uses about 1.3 amps. I have run this unit off of the vehicle many times overnight without noticeable effect on cranking at start in the morning.
I have a single yellow top battery series 35 rated at 48 amp-hours. The smallish battery is because I stole some of the battery tray for an ARB mini-compressor. It was an easy solution at the time, and has worked well up to this point.
Enter, the fridge. I am the proud owner of a new Engel MR040 fridge, and I am wondering if I need to beef up my power situation. Engel says "Typically, when maintaining temperature, the nominal draw of any Engel is under 1 Amp per hour." I am a little skeptical of this figure, but then again it doesn't run constantly like the CPAP, so maybe this is an accurate average. And I live in Minnesota, where overnight temps don't tend to be all that warm.
So if I apply these numbers to their typical use in an overnight camping situation, I come up with 1.3 ah * 8 hours for the CPAP, and 1 ah *~16 hours for the fridge. This adds up to 26.4 ah overnight (again, vs. a battery rated at 48 ah).
So question(s) #1 is: do I need an auxiliary power source of any kind? (And it's corollary: How many ah are needed left over in the morning to start a truck?)
It is also worth noting that I rarely travel alone...but I can't count on a jump start whenever needed.
If I do look at auxiliary power options, things get complicated. I could:
So there are my thoughts so far. What are yours?
- Move the ARB mini-compressor and get a bigger battery, say a series 31. Not as easy as it sounds to move the compressor, but may be possible without rewiring and re-doing air lines. I would go from a 48 ah battery to a 75 ah battery, which seems like plenty on the face of it. The simplicity of this approach is appealing. A new series 31 AGM battery isn't cheap, though. Might be able to get something for my current battery, which is only a year old.
- Simply carry the means to jump start myself, such as those glovebox-size lithium jump starters. They seem to work, and run $80-150, but have little utility otherwise except to charge a cell phone and such. OTOH, they take up almost no room.
- Get a AGM battery jump pack and run the CPAP off of it overnight, thus relieving the vehicle battery of that burden, plus offering jump start backup capability. Takes up more room and weight than the little lithium jump packs, and are a similar price range.
- Dual battery system. I don't like this idea really, I think it is overkill. Quite expensive, heavy, and difficult to fit in the engine compartment. Possibly I could put another battery where the air box is and get a cone filter. I don't see this happening for less than $500 with a new battery and controls.
- Other auxiliary batteries...lithium or otherwise. I don't really know all the options here, but I know they exist.
