While it certainly wont hurt, changing the HPOP res oil doesnt do much.
After all, the oil doesn't just sit in there. It cycles thru and is replenished with filtered oil constantly.
Good oil and filter, and proper intervals is all that is needed.
I changed the oil in mine when I did my first oil change after I bought it and I agree that it looked terrible, much thicker than the engine oil. The engine had about 50k miles on it at that time, was 14 years old and I suspect the HPOP reservoir oil had never been changed before. I bought the truck with no maintenance records. I understand the debate about the need to change it but it wasnt a huge deal to do except that I dropped the screw into the engine valley and couldnt retrieve it. I'll probably change it again at the 15k mile interval and see what it looks like.
When a fluid moves from a restricted channel to an area of greater volume it loses velocity and heavier material falls out and collects in the areas of lowest velocity. It happens in fuel tanks, transmission pans, water heaters, oil pans, etc. I dont see why motor oil running through a 1/4" line into a half quart reservoir would be any exception. When the engine is not running the heavy stuff will settle to the bottom and maybe some of it will get agitated back into solution when the engine is restarted but likely not all and over time it will build up. Frequently when I change fluids in a vehicle I'll collect a sample of the old fluid in a clear glass jar and then it will end up sitting around until I eventually dispose of it. It's always amazing how much crap is in the bottom of the jar when I eventually dump it out. It doesnt matter if its engine oil, PS fluid, brake fluid, transmission fluid.
My guess is the less a vehicle is used the more sludge will collect in the HPOP, at any rate I'll keep checking mine until I establish a comfort level.
This is not 100% accurate. It circulates but doesnt drain when you change your oil. None of these trucks are new any longer and changing your top end oil needs to be routine. I just changed mine, ran a few hundred miles and pure sludge came out of the top end. I will pull some, replace with new, run and and repeat.
I’m certainly not an expert, and I’m not going to hassle anyone who doesn’t... or doesn’t need to, but if you could have thick black sludge inside your engine shouldn’t you check?
100% accurate it is.
Like I said, it isnt going to hurt, but it certainly isn't needed.
The % of people that actually care about this to the point of doing anything is TINY
Hundreds of thousands of 7.3s out there, ALL with high mileage at this point, with zero evidence of this so-called problem.
Simple point is, that isn't a problem.
But if you really feel like doing it, by all means.
Just don't claim it is a solution to a problem that doesn't exist.
Hundreds of thousands of 7.3s out there, ALL with high mileage at this point, with zero evidence of this so-called problem..
