Monroe truck bed
vintageracer
To Infinity and Beyond!
#2
The "short flat" portion of this bed could present a problem with support for a camper with a floor such that is much longer as a slide in bed camper.
You were not specific about the type of "Camper" you would mount on this bed so a little "Mo Info" would certainly be helpful to properly answer your questions.
ericvs
I have a Bradford built flatbed under my camper. I removed the forward 'headache rack' to allow the camper to be much closer to the cab.
I also wonder about the sloped part at the back of that Monroe bed. The camper will not be supported in that area either. I don't know what Articfox states it needs for the camper.
#7
I have, they look good with some good ideas. I found a CM bed as well that's aluminum skin over steel frame. It's flat but 9'4" long so I don't think I can scoot the camper all the way forward. The AF has an integrated bumper with 2 support diagonals that extend about 18" up the belly. The salesman said to just build up a platform to raise camper up.....:rolleyes: Then my wife found the 1172 :confused:
#9
Thanks, how much room in front does that leave?
'After looking at the bellies of a few units the slant on the back of the monroe bed starts to look advantageous if the flat area is long enough. I located one locally so I'll have to take some measurements.
