Move Vehicle with Trailing Arms Off
Salonika
Monterror Pilot
I’m getting ready to do a little welding to repair the forward bushing mount locator rings. I do not want to weld this in my garage due to fire risk. Is it possible to move the truck at all with the trailing arms off or is this just a terrible idea? I only need to push it backwards 15 feet straight back to get it out, weld it up, then 15 feet back in. Is this possible?
CharlieNorth
I have been know to insert extensions for sockets or just metal rod if you have any around. If a joint is double sheer such as trailing arm to axle, most anything is fine for moving around the yard.
The front of the trailing arm, nut and washer without the rubber or not all the rubber will be safe in the yard.
Randy Towles
