need help cannibalizing a power supply
volcomsurfer
okay so i have these led strips in my van I'm trying to run straight off the batteries. So I want to run power from the house batteries to a couple toggle switches. I know the positive is in the middle of the connector end and the negative is the outlying piece so I can cut it open and ohm it out to find which is which. But my question is, is it just that simple? What about the diode? Do I splice it with it or cut that out? I tried google but all I'm finding is people changing the ends, not actually getting rid of the AC/DC converter.
herm
what is the output voltage of the ac/dc ? or what is the input dc voltage of the controller? what "diode" are you talking about?
volcomsurfer
120v ac in/ 12v dc out. the diode I was referring to is the ferrite bead... the little cylinder thing towards the beercan
herm
If all you want is the powercord from that converter, then just cut it off where you like. Nevermind that ferrite lump. Wont hurt anything leaving it or not.
But, depending on the tolerance of your LED appliance,
it might not live long connecting direct to a vehicle what can often operate at 14 plus volts.
With my experience, they all work fine, but have no long term experience to know if slight overvoltage shortens its lifespan.
in my experience, you will want to run a voltage regulator to keep the lights working long term. the lm 317 should work for your needs and is very east to set up. https://en.wikipedia.org/wiki/LM317
4x4junkie
I have a couple of those RGB LED strips with the little remote controller myself.
14.4-15 volts isn't going to hurt the controller box, however the LED strip itself will run noticeably hotter, particularly if it is left on white at full brightness.
What I would do for this is put a simple resistor inline with the DC power lead going into the little controller box. This will drop the voltage down a couple volts to where the LED strip won't get as hot.
Assuming your strip is still full length (300 LEDs), resistors like these should work:
http://www.amazon.com/uxcell®-Wirewound-Ceramic-Cement-Resistor/dp/B008G50AAG
http://www.amazon.com/uxcell®-Tolerance-Aluminum-Wirewound-Resistors/dp/B00TX5X938
If you have a local Fry's Electronics, or one of the few Radio Shack stores that's managed to stick around in your area, you might be able to source a resistor there. Ohm value isn't exceptionally critical, anything between 0.75-1.5 ohm (and rated @ 10 watts or more) should work for this (that is unless you've cut the LED strip shorter, then you need to increase the ohms value by the same amount you've shortened the strip... for example the resistance range would become 1.5-3 ohms if you've cut the strip ~50% shorter).
As for the ferrite bead, it's supposed to reduce radio frequency interference (RFI), which indeed the controller does create a bit of buzzing noise on some of my radio receivers. If you have a CB or ham 2-way radio, it might be better to keep it inline (or put another one on the DC cord just before the controller box). The bead doesn't affect the operation of the LEDs themselves however.
That could work also, except that a 317 has a dropout voltage (minimum input-output voltage differential) of about 2.5 volts, so the LEDs would only get maybe 10 volts when the engine is off (battery voltage), significantly lowering their available brightness.
