Stockton wheel was my first choice due to the fact they are very close to me. When I talked to I found that the new management is all but clueless regarding this truck and rim options. I also ran into a language barrier that made communication difficult both verbally and written. Has anyone had a different experience in the last year?
I just had Stockton build me two 19.5" x 8.25" wheels copied from a set of 4 used Stockton's I'd purchased from an expo member. I went to Stockton Wheel and they measured the old wheels and duplicated it exactly. For future reference my SO number from Stockton Wheel was 5006 and my reference number was Series24 . These were reversible six bolt.
Here are the specs from the invoice:
19.5x8.25 6x8.75BP PW VENTED
BUILD WITH REVERSE MAX BS OF 8-1/8"
PUT 6 OBLONG HOLES WITH
MEASUREMENTS
OF 2-3/4" LONG AND 1-1/2" WIDE
THE WIDTH OF HOLE 3/4 OF THE WAY IS
1-1/4" WIDE
THE SLOT HOLE WILL LINE UP WITH
VALVE STEM HOLE
DISTANCE OF OBLONG HOLE TO
CENTER
BORE HOLE EDGE TO EDGE IS 3-3/4"
DISTANCE FROM CENTER OF OBLONG
HOLE TO CENTERBORE EDGE IS 4-3/8"
CENTERBORE HOLE IS 6-1/2"
DOUBLE TAPER THE STUD HOLE W/
1-3/16" BEVELED
