Hi everyone,
I'm looking for feedback relating to DIY slide-outs and if anyone has used a dovetail slide mechanism? Or, if you have something else that is low profile and capable of supporting heavy loads. This is for a heavy truck application, but I know that a lot of trailer builders use slide-outs so I'm asking in this thread. If there is a better place for this question, please let me know.
I've been considering telescoping SHS (square tube) and wall mounted slides, but neither are giving me what I need. The two most important features are minimising the overall floor thickness, and keeping most of the structure in the floor. The truck bed is 1.35m (4.5') off the ground already so we are looking for every saving on height possible, and trying to keep the centre of mass as low as possible.
The camper is going to be 5m (17') long and 2.4m (8') wide. The slide out is going to be the entire length of the driver's side, and extend out 0.75m (2.5'). And the camper can be taken off the truck by use of jacking legs. What I'd really like to do is have two of the jacking legs in the slide out and the other two on the main box.
I have enough room in the floor to have between 0.6m (2') and 0.9m (3') of overlap between the main box and the slideout, and I can either make the dovetail the entire length of the overlap, or have a shorter carriage at either end.
Ideally, I'd make the mechanism out of mild steel, but could also make it out of 4140 or 5160 if necessary. I'll likely use a brass or bronze gib so I can adjust the engagement as needed. I won't use the gib to lock the mechanism.
Any feedback is appreciated.
