Need For Speed
Supporting Sponsor
Snugpak - Patrol Poncho
The Snugpak® Poncho is a simple over the head, waterproof, smock style piece of useful kit that everyone should have. Designed to be worn over the user as well as the users backpack, if one is being utilized, to help keep you and your gear dry in a down pour. Its generously cut design can allow one to use as an emergency Bivvi if needed. We have gone above the old standard design of what most people think about when thinking of a poncho, we have included an adjustable hood and thumb loops in our design. Located on the chest is a Velcro map pocket with storm flap. Made out of Snugpak’s exclusive Paratex Dry material and with fully taped seams which allows the shell to be 100% waterproof.
Snugpak - Poncho Liner
Temperature::
45°F / 36°F
7°C / 2°C
This Snugpak® Poncho Liner is not your fathers, or Grandfathers, Poncho Liner. Unlike the older square shaped style Poncho Liner many have come to know the Snugpak® Poncho Liner has a dedicated hood with draw cord as well as dedicated sleeves. No more cold chills when lifting up your arms while wearing a Poncho. The other great news is the Snugpak® Poncho Liner is compatible with pretty much any poncho on the market, though it does work best with Snugpak’s Enhanced Poncho. Why you ask? Well is is simply because the Snugpak® Enhanced Poncho too has dedicated sleeves and because of this fact the Poncho Liner acts like a jacket liner to insulate and improve the performance when needed, or desired.
Snugpak - Snugnut
The Snugnut is an insulated hat and earmuffs in one. Constructed from the same high performance fabrics and Softie insulation used in our high performance sleeping bags this UK made deerstalker style hat is the ultimate in both day and night cold weather protection for your nut (AKA, Head) and ears.
Snugpak - GeoThermal Gloves
The GeoThermal insulated glove is perfect for keeping your hands warm, comfortable and dry thanks to the fully waterproof fabric. The GeoThermal glove has a one hand operated adjustable wrist strap and elasticized opening to ensure a draft free snugfit. Reinforced fingers and palm stitching for remarkable touch and extra durability.
Hydro-Tex® - Fully waterproof, seamless, breathable insert.
Snugpak - Sleeka Elite Reversible
Temperature::
23°F / 14°F
-5°C / -10°C
The Sleeka Elite Reversible™jacket is a spin-off of our extremely popular Original Sleeka jackets. The Sleeka Elite Reversible is equipped with reinforced patches covering all stress points; shoulder, elbow and cuff on the Olive side only and supplied with a heavy duty compression stuff sack so you can really appreciate the benefit of our highly compressible Softie® insulation. Both sides of the jacket are equally equipped with easy to access pockets. This jacket is more for those concerned with cost but yet with the same quality and performance they have come to know and expect of Snugpak®.
Snugpak - SJ-3 JACKET
Temperature::
32°F / 23°F
0°C / -5°C
The SJ-3 Jacket is ideal for spring and summer keeping the user comfortable down to 32°F (0°C). The SJ-3 Jacket uses Snugpak’s high tech proprietary fabrics and insulation. Paratex Micro is used as the outer shell material and Paratex Light material is used as the inner lining material. The insulation used is Softie® Premier and this filling effectively traps the air within it and then creates the warmth and comfort one expects every time it is worn. Because Softie® Premier Insulation is used it allows the user to really compress it when not worn to take up as little space as possible but yet to be at the ready.
The SJ-3 Jacket has been designed and tailored to fit the contours of the end users body, with a weather-resistant zip, and a high neck design to keep out draughts, sleek concealed pocket and more. The whole range of the SJ Jackets and SP Pants are manufactured in Snugpak’s West Yorkshire UK factory, quilted on their state of the art machinery and hand assembled by our skilled sewing staff.
Available in: OLIVE - BLACK - MULTICAM - A-TACS
Snugpak - SJ-6 JACKETTemperature::
23°F / 14°F
-5°C / -10°C
The SJ-6 Jacket is very similar to our SJ-3 Jacket but with an added features a TS1 hood that rolls away into the collar when not in use. Also the SJ-6 has an additional layer of Softie® Premier Insulation. With this additional insulation the SJ-6 Jacket has a temperature comfort rating of 23°F (-5°C). Paratex Micro is used as the outer shell material and Paratex Light material is used as the inner, lining material. The insulation used is Softie® Premier and this filling effectively traps the air within it and then creates the warmth and comfort one expects from a Snugpak® product.
The SJ-6 Jacket has been designed and tailored to fit the contours of the end users body, with a weather-resistant zip, highly water-resistant outer fabric and a high neck design to keep out draughts, sleek concealed pockets and more. The whole range of the SJ Jackets and SP Pants are manufactured in Snugpak’s West Yorkshire UK factory, quilted on their state of the art machinery and hand assembled by our skilled sewing staff.
Snugpak - SJ-9 JACKET
Temperature::
14°F / 5°F
-10°C / -15°C
The SJ-9 Jacket was designed with extreme cold weather in mind. With its insulated hood theSJ-9 Jacket is ideal for range work and stationary outdoor activities in extreme temperatures. The comfort rating for the SJ-9 Cold Weather Jacket is 14°F (-10°C). Paratex Micro is used as the outer shell material and Paratex Light material is used as the inner, lining material. It utilizes Snugpak’s proprietary Softie® Premier Insulation, the same filling we use in our high end UK Made Sleeping Bags.
The Paratex outer fabric used is a very closely woven type of fabric allowing it to be extra strong, windproof and highly water-resistant as well as exhibits effective wicking capabilities. The SJ-9 Jacket has been designed and tailored to fit the contours of the end users body, with a weather-resistant zip and a high neck design to keep out draughts, sleek concealed pockets and more. The whole range of the SJ Jackets and SP Pants are manufactured in Snugpak’s West Yorkshire UK factory, quilted on their state of the art machinery and hand assembled by our skilled sewing staff.
Snugpak - SP-6 PANTS
Temperature::
23°F / 14°F
-5°C / -10°C
The SP-6 Pants uses the same Paratex Micro, Paratex Light and Softie® Premier Insulation fill as the NEW SJ-6 Jacket. The insulation used is Softie® Premier and this filling effectively traps the air within it and then creates the warmth and comfort one expects from a Snugpak® product. The waist band is elastic to accommodate layering when in colder conditions and has a Velcro® and zipper closure. At the ankle there is a 12 zip allowing you to get the pants on over your boots with ease. The SP-6 Pants are a great compliment to the NEW SJ Series of Jackets by Snugpak®.
Snugpak - Sleeka SalopettesTemperature::
23°F / 14°F
-5°C / -10°C
Insulated pants with Nylon Bib and Suspender System. Sleeka Salopettes utilize fiber and fabric technologies giving warmth and durability you have come to expect from Snugpak®. These mid weight pants are perfect for outdoor activities where you’re subject to long periods of inactivity. As well as being water repellent, breathable and obtaining temperature rating of 14°F you have all the requisites for a very warm and lightweight multifunctional clothing system that can be used for any outdoor activity. Ideal for use with the Sleeka Reversible Jacket and the SJ Series.
Available Colors: Olive, Black, Multicam & A-TACS
Temperature::
45°F / 36°F
7°C / 2°C
Snugpak - Snugnut
Temperature::
23°F / 14°F
-5°C / -10°C
Temperature::
32°F / 23°F
0°C / -5°C
23°F / 14°F
-5°C / -10°C
Temperature::
14°F / 5°F
-10°C / -15°C
Temperature::
23°F / 14°F
-5°C / -10°C
23°F / 14°F
-5°C / -10°C
