OverlandMitsu
So not sure if this is in the right section...but. I am doing some research on getting the most lift out of our Outlander Sport. There are a few ways to get 1-2" but I'd really like to do a possible coil over swap either from a different make/model or a good aftermarket approach. We'd like to achieve around a 4-5" if possible. I know they'll be a lot of fab work and customization which we have no problem doing. One of the main things I am concerned with is drive shaft angles. The vehicle is only FWD but we are looking into doing a AWD swap from an outlander that has all the AWD components which we have been piecing together. Unfortunately body lift is out of the books so can only rely on a good suspension re-work.
Would you recommend starting off with finding makes/models that share a similar plateform that offer a lift or doing a complete aftermarket coil over swap and welding up new brackets/mounts etc..?
Someone photoshopped this outlander but it has the height we are after
Thanks for any and all info!
