The $500 Grandby Project....
BajaSurfRig
Hi Guys,
I just picked up a 1983 Grandby for $500 on Craigslist in Santa Rosa and for the price it is a killer deal (new canvas and everything works). It has a poorly done homemade paint job and some bruises and dents but all in all it is a killer little set up. While cleaning it today I noticed what looked like little mold spores in the headliner. Can I just bleach/ clean the headliner or should I tear the headliner out and replace it with something else (it seems that condensation is always an issue in the FWC's, it seems like having a porous headliner isn't the best idea).
I plan on re-sealing the roof in the near future with SilkaFlex Polyurethane, but from what I can tell it looks like the roof is somewhat leak free.
Has anyone ever replaced the headliner with 1/8" ply or masonite and painted it (with rigid foam closed celled insulation to replace the old insulation)? I don't have a big budget and plan on slowly fixing up the camper to my needs. I would most likely install fantastic fans and new LED lighting where needed when I replace the headliner (if it is needed).
Does anyone know if there is aluminum framing running under the windows lengthwise on these older FWC's? This thing was loaded/unloaded with cable jacks its whole life and has a little bit of damage where the jacks make contact with it under both windows (I am planning on installing some REICO mechanical corner jacks in the near future).
I will upload some pictures later today...
BajaSurfRig
Here is a shot of where the old cable jacks damaged part of the camper. Any idea if there is aluminum framing on this section or is it just plywood replacement?
BajaSurfRig
Unfortunately the previous owner replaced the cabover section under the bed with OSB...... It is solid for now. I might just cut a sheet of aluminum to cover it and keep it out of the weather
