hour
Anyone used these? I didn't even know they existed until the other day.
$140 for 300w of charging power, bluetooth monitoring ability, and has a lifepo4 preset (14.2 absorption, float/storage at 13.5)
I don't know what to make of that blurb above and how much of it pertains to lifepo4, but they do specifically state a float/storage voltage for this battery type at 13.5v.
Cons: in loading the demo for this unit on the victron app it doesn't allow customizing charge parameters, only presets. What a mistake, they could have treated it just their MPPT charge controllers and given the user complete freedom. They could have even used the same layouts and recycled code (from an app development perspective)
Pros: Obviously bluetooth for monitoring, ability to charge your lead/agm/life batteries with one unit, flip from 25a to 10a from your couch (on the 25a unit), float voltage and whatever the automatic storage sensing thing is in quotes above.
I would jump on this before getting a dumb charger @ 14.6 volts from Progressive Dynamics as Battleborn suggests and sells on their website. The absorption is slightly lower than battleborn recommends (14.4-14.6v, this goes to 14.2 for lifepo4 setting) which still may be higher than one wishes to go, and might not get you to the point that balancing happens. Not much of a concern for DIY battery jobs.
The IP22 12v/30a Victron is $0-20 more than the 30a Progressive Dynamics 14.6v power supply looking unit from Battleborn at $200.
The IP67 12/25a Victron is $140 and for less than $6 more you can get this rubber bumper thing for it
Sounds like a good buy to me. Have no idea when the product came out and haven't seen anything on here. The IP67 model could easily be mounted in a vehicle or truck bed and run from shore power or any generator. If you lop off the ring connectors the unit comes with, you could standardize on anderson powerpoles or whatever and remove it to charge your other batteries when needed.
Thoughts?
The storage mode kicks in whenever the battery has not been subjected to discharge during 24 hours. In the storage mode float voltage is reduced to 2,2 V/cell (13,2 V for a 12 V battery) to minimise gassing and corrosion of the positive plates. Once a week the voltage is raised back to the absorption level to ‘equalize’ the battery. This feature prevents stratification of the electrolyte and sulphation, a major cause of early battery failure.
Thoughts?
