Look what I found!
The guy I bought it from had a new tub fabricated to the same specs as the original, just made out of 1/8" steel this time around. The sides and bottom are made of a single sheet of steel with the front and rear welded on. The front and rear sheets need to be cut, as you can see in the pics. The tub isn't bolted to the frame yet either. I'm going to need to weld some angle iron onto the bottom in order to bolt the tub to the frame.
I'm live in the DFW Metroplex so if any of you guys live here and can help i need it!:
Step 1: Cutting. I need to find someone with a cutting torch or plasma cutter. I'll bring beer and reimburse for any costs incurred. Disclaimer: The author of this thread is not responsible for any accidents caused by anyone drunkenly wielding a cutting torch/plasma cutter.
Step 2: Welding. I need to find Someone with a MIG or TIG welder and welding skills. Again, I'll provide beer and reimbursement for any cost incurred. Disclaimer: The author of this thread is not responsible for any accidents caused by anyone drunkenly wielding a MIG/TIG welding instrument.
Step 3: Sand Blasting. I used ICA to sandblast and powdercoat my PSC Rocker Knockers so I'll probably use them again for this sandblasting. That is unless anyone knows of a shop that'll sandblast for cheap. Please let me know!
Step 4. Paint. I'll probably buy a pneumatic paint gun and do this on my own.
Thanks in advance for comments/suggestions. I really need help from those of you who have welders/cutting equipment.
Thanks,
Dawson
Thanks,
Dawson
