alexrex20
this is my current setup: 115lb wheel/tire mounted in the roof basket:
and it is the biggest PITA to get it up there by myself. it is currently my only option. the tire does not fit in the OEM spot under the vehicle, and it's definitely not practical for my spare tire to take up my entire trunk.
nobody makes an off-the-shelf rear bumper with tire carrier, so one would have to be custom made. i just don't have the time to drop off my vehicle for a week or two, to have the bumper/carrier designed/fabricated/installed.
then i found this:
http://cbioffroadfab.com/v-web/gallery/TIRE-CARRIERS
what is everyone's opinion on this setup? obviously, i will lose departure angle (the minivan does get wheeled as often as possible), and it will be a chore to swing down and lift back up the wheel/tire every time i need access to the trunk, but it is admittedly easier to mount/dismount the spare, than the current setup on the roof. there's also the whole COG thing, but the effects are arguable.
would this be a nuisance to everyone? it is my daily driver. this hitch-mount setup would afford greater convenience if and when i need my spare tire, but i presume it will get annoying having to lower/raise it EVERY time i need access to the trunk.
then i found this:
